12” Radial tires Velocity ST145R12 D/8PR
Discussion in 'Tires / Brakes / Bearings / Axles' started by megcabra, Jul 1, 2018.
  1. megcabra
    megcabra Well-Known Member
    I had planned on replacing our 2010 date code Load-Star 12” 5.30-C bias-ply tires with radials and moving the bias-plys to our utility trailer at the end of the season. But as luck would have it the 12” 4.80-B tires on the utility trailer had dry rotted and lost air after 11 years. So I jumped on a set of 3 Radial Velocity TR088 ST145R12 D/8PR from Giga-Tires.com for $93.00USD and moved the old Pop-Up tires to the 4x6 utility trailer. There was plenty of clearance and they should be fine for a few more years.
    I had the new tires mounted at my local Costco for $14 each which included balancing and Nitrogen. I never balanced trailer tires before but since it was included how could I say no.
    Not being familiar with this brand and the lack of reviews I’ll be rolling the dice when the Pop-Up hits the road next month. Wish me luck and I’ll let you all know how they do.
    0A09F922-3C74-49F9-9A86-B31DA1684FFD.jpeg 52CE35C1-316D-4EFE-993F-F075D67341A4.jpeg 4EF54587-2EC8-4090-93D5-BF9033C5B81F.jpeg 0B3E87E4-C440-4473-B1C7-C724527ADB46.jpeg FFC56872-497F-4A7B-8B5D-494A5711E866.jpeg EB957668-81D8-40FF-B8D5-84827FC57D5F.jpeg D60B4C68-8C29-493D-9ADB-195AE8873BBD.jpeg
  2. Sjm9911
    2,108
    827
    I wosh you luck, the have to be better then the old ones! I just did the same and all the reviews on everybrand had lots of bad reviews. So just go with it. I hope the radials ride better!
    megcabra likes this.
  3. nineoaks2004
    5,799
    2,063
    Graceville, Florida
    Make sure you keep a check on the tire pressures and max speed.
  4. megcabra
    They do show a M 88 rating and it looks like that is 81MPH-130 km/h. Not sure I ever had our Coleman over 70MPH-110km/h. The old bias-ply tires had 70 PSI in them and could go up to 85 PSI. The new radials are at 60 PSI and can go up to 65 PSI per the tire info. So that is a lower difference. It will be interesting to see how they dissipate heat as the old tires did warm up the hubs.
  5. Sjm9911
    2,108
    827
    Supost to do better with heat at higher speeds and a smoother tracking. Just not as tough sidewalls, and off road. That was my take. I haven't taken mine out to test it, and even if I did I wouldent be able to tell.
  6. nineoaks2004
    5,799
    2,063
    Graceville, Florida
    I bought a laser thermometer at HF for $20.00 and keep it in my glove compartment, I check the tires and hub temperature when I stop, only takes a few minutes .
    xxxapache, megcabra and Sjm9911 like this.
  7. Adam H
    Adam H Active Member
    311
    99
    Aug 22, 2015
    I put Velocity tires on my Avalon in 2015 and all has been well.
    Adam
  8. Sjm9911
    2,108
    827
    How are the tires holding up? Mine are good. I didn't get the laser heat gun , but did check the temp by hand on the tires and hubs when we stopped. The chemo tires I got worked well, and the radials were smoother.
  9. megcabra
    So far so good. We have only put on them about 100miles/160km and I did the hand test several times during the drive and they remained cool. The old bias-ply tires did not take long to warm up so that is a good sign. Also the tires kept the 60PSI spot on, but that may be attributed to the Nitrogen Costco filled them with. The test will come in October when we head to the Sewer Rally which will have about a 260mile/420km round trip with a good amount of Interstate high speed driving.
  10. Sjm9911
    2,108
    827
    It will be fine. I did 600 miles on my cheap o tires , worked out well.
