1994 Skamper cable replacement
Discussion in 'Lift Systems' started by Ragazzaccio, Jul 11, 2019.
  1. Ragazzaccio
    Ragazzaccio New Member
    Mar 27, 2017
    So I’m in the midst of replacing the cable of my Goshen lift system... I found a great video on YouTube that basically explains how to do everything... the main problem is, all the videos and instructions I’ve seen are for lift systems where the crank is found at the front of the trailer. My crank is on the front driver side of your the trailer so I’m unsure how to reconnect the cable to the winch. I’m guessing I’ll need to lift the roof manually and open a panel on the interior to access the winch to reconnect? There is a pulley at the front near the tongue with a hole where you can slide the cable
  2. Ragazzaccio
    Mar 27, 2017
    F6A49631-7610-4C0A-8072-BBA08EC1F2E5.jpeg 78B25C56-A7AC-45C7-9FE0-19091899B4B7.jpeg
