1996 Jayco Eagle 10 + 2013 Ford Edge V6
Discussion in 'Etrailer.com Trailers and Towing Forum' started by mstate060, Apr 10, 2017.
  1. mstate060
    mstate060 New Member
    Aug 17, 2016
    Hey All,
    I own a 1996 Jayco Eagle 10 with a "dry weight" of 1,405lbs and a GVWR 2,205lbs. I also own a 2013 Ford Edge V6 which according to Fords website and the door sticker has a max towing weight of 3,500lbs. Would you guys feel comfortable towing and does anyone have similar experience with a Ford Edge? Just curious how they tow. I had an F-150 up until this year so towing was never an issue until now.
    Thanks for any feedback.
  2. JPBar
    JPBar Well-Known Member
    1,694
    432
    Sep 22, 2016
    Texas
    Should be fine
  3. mstate060
    Aug 17, 2016
    Thanks. It doesnt appear that my PUP has surge breaks and my Edge doesnt currently have an electronic break system. Do you think I would need to have that installed or at this weight will I be okay?
  4. JPBar
    1,694
    432
    Sep 22, 2016
    Texas
    If the PUP has electric brakes than you need install a break controller in the Edge
  5. NMroamer
    NMroamer Active Member
    310
    90
    Apr 21, 2016
    Albuquerque NM
    We had a similar setup with an 2010 Escape.
    Tongue weight is an issue with the front wheel drive. Traction loss becomes a problem.
  6. JPBar
    1,694
    432
    Sep 22, 2016
    Texas
  7. mstate060
    Aug 17, 2016
    Thank you. I took a look, I have an Eagle 10 UD. As far as I can tell, the PUP has no brakes on it. Ive done a physical inspection of the camper as well and I see no drum or break system at all. Not sure if they were removed by a previous owner or if the PUP never had them. Makes me wonder if Ill need them or not... lol
  8. JPBar
    1,694
    432
    Sep 22, 2016
    Texas
    Think you will be fine, just drive a little more careful and leave more distance between you and the guy in front of you and start slowing down a little sooner. You can practice this to see how things are going to act by towing camper on highway and in town when there is not a lot of traffic. Have fun and just use common sense, and you will be fine.
  9. mstate060
    Aug 17, 2016
    Yep I agree. Thanks for the help.
  10. etrailerJohn
    etrailerJohn Member
    96
    Apr 19, 2016
    Wentzville, MO
    We offer all the equipment needed to set up your Ford Edge for towing.
    You'll want to ensure that the fully loaded trailer weight doesn't exceed the towing capabilities of your Ford Edg.
    For more information, use the link below:
    https://www.etrailer.com/expert-43.html
