2001 Coleman Utah Wheel bearing
Discussion in 'Tires / Brakes / Bearings / Axles' started by thrawn5499, May 15, 2019.
  1. thrawn5499
    thrawn5499 New Member
    Jun 25, 2018
    Hi, I am getting ready for a camping trip and I thought I would pull the wheel bearings off and inspect them and then repack them. I am thinking now, I might just buy another set and put new ones on, even if the old ones are fie. Then I can clean and repack the others and have them for a spare set on the road. The problem is I don't have the camper near me right now to check to see what size I need. I will be around it this weekend, but that is when I plan to do the swap. I would like to get the parts on order so I have them here when I need them. Can anyone tell me the parts I need to order? Will these fit?
    https://www.ebay.com/itm/Complete-T...e=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
    Thanks for the help!
  2. GreyFox
    GreyFox Well-Known Member
    772
    306
    Oct 10, 2018
    S Ontario
  3. thrawn5499
    Jun 25, 2018
    Thanks I didn't think to look there. so i think the one listed on that auction will work. not sure about the item "A" in that PDF
    Here is what the PDF lists.
    Crossover Numbers To Purchase Locally
    A 13194TM or 198138SP21 Grease Seal (3588,89)
    171255VB Grease Seal (all except 3588, 89) <--- I think I need the 171255 (don't know what VB is)
    B L44649 Bearing (3588,89 x2/ all others xl "outer") <--guess I need this one too
    L68149 Bearing (large inner xl all except 3588, 89) <--- I think I need the L68149
    C L44610 Race (3588,89 x2/ all others xl "outer") <--- and this :)
    L68111 Race (large inner xl all except 3588, 89) <--- I think I need the L68111
    here is what the auction says.
    This auction includes the following:
    (1) L44649 Outer Bearing
    (1) L68149 Inner Bearing
    (1) L44610 Outer Race
    (1) L68111 Inner Race
    (1) Seal: 171255TC (10-19) Seal Cross reference numbers below:
    Dexter # Transcom # National # NOK # Chicago Rawhide #
    010-019-00 171255TB 473336 AD2548EO
  4. 1380ken
    1380ken Well-Known Member
    1,885
    390
    Nov 7, 2013
    Mass
    Better off buying Timken bearings or another top brand.
    nineoaks2004 likes this.
  5. ken1207
    ken1207 Member
    70
    Aug 26, 2012
    That is what I did, I used timken bearings and for the seal I used national, a really nice seal.
  6. kmbarreiros
    kmbarreiros Member
    57
    Jun 17, 2014
    Fairhaven, MA
