2007 fleetwood highlander niagara wiring problem
Discussion in 'Wiring' started by cdelappe, Feb 8, 2018.
  1. cdelappe
    cdelappe New Member
    Mar 12, 2011
    New to us pop up. New battery, but not wired up. Are there any suggestions for a model specific wiring diagram. It is now plugged to shore power and have interior lights, h2o pump. Need advice to hook up battery so I do not cause problems.
  2. Raycfe
    12,816
    490
    Right at the tongue should be a small white connector with a black and white wire. This is your battery connection. Just cut the plug off and connect these wires to the battery. The black is the positive and white is the negative (common ground wire). If you have no plug, connect the negative (use white 10 gauge wire) to the metal tailer frame. As for the positive use a 10 gauge black with a 20 or 30 amp fuse or circuit breaker near the battery post connection and the other end will get spliced into the heavy black wire in the wiring harness that runs along the tongue to you TV(tow vehicle).
  3. jnc
    It may help if you can post a picture of the wires that are there.
  4. theseus
    theseus Centerville, OH
    2,518
    257
    Feb 6, 2007
    Centerville, OH
  5. Boatnman
    Boatnman Well-Known Member
    1,444
    315
    Jan 19, 2017
    western Colorado
  6. jnc
    ya what he said /\
