3 way fridge question
Discussion in 'Refrigerators and Coolers' started by crazymama30, Jul 5, 2018.
  1. crazymama30
    crazymama30 Active Member
    211
    54
    Apr 1, 2017
    So i have a rockwood high wall. I don't if it has an auto shut off when it pops down. I am wondering first of all if my fridge will run off battery while in transit, and if it does will I have enough battery for my trip after driving for 2 or 3 hours? We don't spend much time in the pup while camping, just cooking and sleeping. I will put the fridge on propane once we re at the sight, I am just not comfortable driving with it running.
  2. Raycfe
    12,816
    490
    Running the refrigerator on 12 volts is a power hog. It will put a big draw on the battery. Maybe if you get enough power from the TV it will be alright. I never ran the refrigerator on 12 volts traveling. Just have it running on 110 a day or two before leaving. Pack it the night before and leave it closed. Ours was OK for our trips. The other thing you can do is bring a spare battery.
    KamperKel and crazymama30 like this.
  3. Sjm9911
    746
    255
    Lots run off propane when travelling.
  4. crazymama30
    211
    54
    Apr 1, 2017
    I know lots run off propane, and I can respect everyone's choice to do what they please, but I am just not comfortable with that.
  5. chambo
    chambo Active Member
    329
    88
    Apr 27, 2015
    Southern California
    Your TV will probably produce enough juice to run the fridge on 12v, but if you stop for more than 20-30 minutes you'll probably kill the battery. 12v is the least effective means of cooling a 3-way fridge and runs the risk of killing your battery. Lots of people (including me) tow with the fridge on propane and there is a lot of debate over the issue. Do what feels right for you. If towing with propane is out of the question, then I would pre-cool the fridge for 24 hours, pack up and throw in a few ice packs, and tow with it off. You should be OK for a few hours.
  6. Sjm9911
    746
    255
    I plan to pre cool mine and load it up with frozen food for the week. Ill take along another cooler for stuff you can't freeze and need imiadeatly.
    crazymama30 likes this.
  7. Toedtoes
    Toedtoes Active Member
    241
    158
    May 28, 2018
    I have a 3 way fridge in the clipper. I cool it down on shore power before I leave. I fill it up with food and add a couple frozen blue ice packs if there's a lot of empty space.
    I can go a good 4 hour drive without any warming. The fridge stays cold and when I reach my campsite I turn it on with propane.
  8. Dingit
    Dingit Active Member
    330
    109
    Mar 8, 2017
    I have a related question. If the controls to the fridge are on the inside, like they are on our NTU 2008 Fleetwood, and you can't get in there when the top is down, how do you deal with changing the power source on a long drive?
    My other camper's fridge will automatically change based on whatever power source is available even though we don't actually use that function because we can get in there and manually change it whenever we want en route.
  9. crazymama30
    211
    54
    Apr 1, 2017
    There should be a setting called auto, and then the fridge senses what power source to use, with 110 always being default from what I understand. I have buttons on the outside of my fridge for this
  10. Dingit
    330
    109
    Mar 8, 2017
    I'll have to check, but I don't think mine has that. (The model that does have it is covered in the same manual. Grr.) My other camper does have the auto setting, and it doesn't need it. [:(!]
    I'm gonna call this one a win for Rockwood!
  11. Toedtoes
    241
    158
    May 28, 2018
    If it doesn't have an auto setting and you can't access the controls enroute, then you need to choose one power source for the drive.
    If you're going to be stopped for several hours on the road, then you best not choose 12v, if you have any restricted tunnels, etc., then you don't want propane.
  12. RetAF
    RetAF Member
    130
    Apr 22, 2010
    I use 12v when travelling all the time. I have used propane some when travelling, but the flame frequently blows out so I gave up on that. My TV does a decent job of charging the battery so I have no problem stopping for meals enroute and still having charge left when I get to the campground. If camping without hookups, I bring a Honda 2000i generator to top off the battery when needed. As mentioned by others, get the fridge and the food in it good and cold before you leave home.
  13. Raycfe
    12,816
    490
    The controls on a refrigerator are usually inside the lower OUTSIDE compartment. for Popups.
  14. Dingit
    330
    109
    Mar 8, 2017
    Thanks all. This one doesn't have controls on the outside; the panels on the vent compartments are screwed down and not hinged.
    I don't know yet if it'll blow out on propane but it is probably pretty similar to your Sequoia, RetAF, so maybe I should plan on DC. Do you know if you can cut off the house battery while parked for a few hours and expect the fridge to start up again on DC on its own when you reconnect the battery?
  15. nineoaks2004
    4,281
    1,193
    Graceville, Florida
    According to the manual for mine it says that the reefer will hold temp for about 8 hours.
    I always start mine several days ahead of time, and also make sure that everything placed inside is already cooled from the reefer in the house. if I were to make a longer trip i would get dry ice and put inside the reefer (wrapped n paper)
