96 Palomino TXL-SC start rebuild
Discussion in 'Checkout My Rig !' started by omahadlr, Feb 10, 2018.
  1. omahadlr
    omahadlr Member
    97
    18
    Jan 19, 2018
    Fairview Heights, IL.
    Well, here we go! Just a neighbor and I starting on this roof project . Yesterday was day 1 and it took hrs to get that a/c off of the roof. Gasket must have sealed good! After removal we were pleasantly surprised to see the wood framework is perfect.
    We're thinking that the back half of the roof is fine. We'll see.
    Took the hard walls down and that's all we had time for. One came down and smashed my finger. (It's ok )
    Next week will be warmer.
    I will post pics as we move along.
    20180209_101902.jpg 20180209_102010.jpg 20180209_145512.jpg 20180209_163000.jpg 20180209_101854.jpg
    Ladiesman likes this.
  2. Ladiesman
    Ladiesman Active Member
    111
    26
    Feb 6, 2018
    Whats the plan for the roof? I see the side boards need rebuilding are you planning on rebuilding the entire roof or just the sides and then sealing and coating the roof m
  3. omahadlr
    omahadlr Member
    97
    18
    Jan 19, 2018
    Definitely new sideboard. I think after we take those off we're going to start peeling off the roof covering from front to back and see how far the wood underneath is bad. This is a first time learning experience for both of us.
  4. jnc
    Ok I'm in for the ride.
    omahadlr likes this.
  5. omahadlr
    omahadlr Member
    97
    18
    Jan 19, 2018
    Well we got the roof off! 20180213_142015.jpg 20180213_141645.jpg 20180213_141600.jpg
  6. omahadlr
    omahadlr Member
    97
    18
    Jan 19, 2018
    Had to move roof in the garage. Tight fit.
  7. omahadlr
    omahadlr Member
    97
    18
    Jan 19, 2018
    So, this board that flips down before pulling bunk out is starting to rot. Only about an inch. Trying to decide what to do. I'd like to replace the whole board to make it right. How to get the skin off without damage is my concern.
  8. omahadlr
    omahadlr Member
    97
    18
    Jan 19, 2018
    This
  9. omahadlr
    omahadlr Member
    97
    18
    Jan 19, 2018
    Got the trim off gently with putty knife and hammer. It's rotten on the bottom too. So, gonna replace board. Hope that I can get the skin off intact. 20180219_165339.jpg
  10. omahadlr
    omahadlr Member
    97
    18
    Jan 19, 2018
  11. omahadlr
    omahadlr Member
    97
    18
    Jan 19, 2018
    Well I rebuilt the end boards. Was a struggle to get the trim on!
  12. omahadlr
    omahadlr Member
    97
    18
    Jan 19, 2018
    Took off the trim that goes around the bottom off the roof. Most time consuming is cleaning all of the old glue off! 15197867694811815518740.jpg 1519786826141278441333.jpg
  13. omahadlr
    omahadlr Member
    97
    18
    Jan 19, 2018
    Well I scraped all of the Styrofoam insulation off. It doesn't look like I can save hardly any wood. I think I'm going to add 1 or 2 extra supports on this front section. There is nothing there for 6 feet. 15209711367671592389704.jpg 15209711946271906524708.jpg
  14. jnc
    This is a good time to add a roof rack if ya ever wanted one.
  15. omahadlr
    omahadlr Member
    97
    18
    Jan 19, 2018
    I have a roof rack on my Tahoe if needed. I think if I mount anything to the roof it'll be a solar panel. I'll think about that later. For now I gotta replace the bad wood and put in insulation. I hope that this JM foil-faced foam sheathing will be good. Haven't decided on what to use for ceiling.
  16. omahadlr
    omahadlr Member
    97
    18
    Jan 19, 2018
    Well I've decided to replace the top skin of the camper. If I'm going to rebuild the frame, insulation and ceiling I should do it all new. This Filon has got tears and holes that I was gonna patch but, there's to much damage. 1522107583986246550925.jpg
    jnc likes this.
  17. omahadlr
    omahadlr Member
    97
    18
    Jan 19, 2018
    So, after a lot of confusing research I'm leaning towards the Superflex roof. 8.5' x 15'. I found it on Amazon for 179.99. If anyone reads this and has an opinion please share.
  18. jnc
    Go with the 9' so it will cover the sidewalls also.
    sawdusty and omahadlr like this.
  19. omahadlr
    omahadlr Member
    97
    18
    Jan 19, 2018
    I was thinking about whether the 8 1/2 wide or the 9 1/2 wide.. The existing top is 7 1/4 wide. The sideboard which I'm wanting to cover also is at it's most width is 5 1/8" x 2.
  20. jnc
    I read a post were the guy wrapped the rubber up under the sides right into the interior for dry edges. He even folded the corners like wrapping a present and used a heat gun on the folds to make them blend into a sealed edge.
