A/C Causing Roof to Lean
Discussion in 'Heating / Cooling Systems' started by Jml96sv, Jun 11, 2019.
  1. Jml96sv
    Jml96sv Member
    53
    Feb 19, 2017
    Hi All,
    I have a '99 Jayco Heritage Laurel with A/C (I think it is a Coleman Mach 3). The A/C unit is raised on one side in the rear corner which appears to be causing the roof to lean in the opposite direction. The hole is off center(Factory Cut-Out). Will longer bolts into the A/C unit help grab the threads and tighten it down onto the roof? Sorry about the lack of detail, this is the best way I can describe the issue. Please feel free to ask any questions. Any advice would be appreciated.
  2. bheff
    bheff Active Member
    302
    86
    Feb 24, 2011
    Are you saying the corner with the A/C is Higher than the opposite corner?
    Is the A/C loose? If not, different screws make a difference.
  3. bols2Dawall
    bols2Dawall S.W. Ontario
    1,419
    127
    May 19, 2010
    Lasalle Ontario
    Take the A/C unit off or moved out of the way and install a new gasket , should be replaced every 6 or 7 years especially if it's stored outside
  4. Jml96sv
    Jml96sv Member
    53
    Feb 19, 2017
    The A/C is in the center of the roof from front to back but is closer to the road side. The roof leans to the road side. It was tight, would longer screws help bring it into alignment?
  5. SteveP
    SteveP Well-Known Member
    1,252
    290
    If what I'm reading is what you're trying to ask, no. Is the roof the same height on each side, measured from the top of the box to the bottom of the roof side board? Are you sure the trailer is correctly leveled?
  6. Jml96sv
    Jml96sv Member
    53
    Feb 19, 2017
    The trailer is level. The lifter arms are slightly bending towards the road side. The hole is from the factory. The roof is internally braced based on other jayco's of the same year that I have seen with A/C. I am just perplexed as to why my roof is leaning.
  7. bheff
    bheff Active Member
    302
    86
    Feb 24, 2011
    Sounds like it may be more of adjustment issue with the cables.
    And I need to edit my first reply. I left out the word "wont". If it is right, longer screws wont fix anything.
  8. SteveP
    1,252
    290
    My AC is also placed to the road side, I'd say 3/4 to 1/4 of the roof to the centerline of the AC. Moving it around couldn't affect the roof balance. Either the pup is not level or the roof is not level on the pup.
  9. Jml96sv
    Jml96sv Member
    53
    Feb 19, 2017
    How do I adjust the cables and fix the tension?
  10. SteveP
    1,252
    290
    Colemans are different and I wouldn't want to lead you wrong. Search through the Lift systems section for "whiffle tree." Or maybe one of the Fleetwood/Coleman guys will come to help out.
  11. Jml96sv
    Jml96sv Member
    53
    Feb 19, 2017
  12. Sjm9911
    3,414
    1,605
    Not sure about your pup, but i would look to see if anything is loose at the top of the lift arms, where it connects to the roof. They should have play in them but nothing like leaning.
  13. Jml96sv
    Jml96sv Member
    53
    Feb 19, 2017
  14. Jml96sv
    Jml96sv Member
    53
    Feb 19, 2017
    I found the problem. The front curbside lift arm was loos . Turns out the top plate that attaches the lift arm to the roof came unglued/unepoxyed. Now to secure it
    The image below is the plate that sits on top of the arm and attaches the bolt assembly to the roof. https://photos.app.goo.gl/ppwpbx4rHCd2SRrY7
    Orchid and Sjm9911 like this.
  15. Sjm9911
    3,414
    1,605
    Good , now all you have to do is fix it!
  16. Jml96sv
    Jml96sv Member
    53
    Feb 19, 2017
    Gorilla Glue worked great.
  17. Jml96sv
    Jml96sv Member
    53
    Feb 19, 2017
    Thanks for the advice. This forum is a great resource . I have learned a lot.
