a/c selector switch
Discussion in 'Heating / Cooling Systems' started by pafree, Feb 14, 2013.
  1. pafree
    pafree New Member
    49
    Jan 17, 2013
    1996 Jayco eagle series 10
    Coleman TSR a/c only.
    the knob broke off the selector switch and also found that one of the spade connectors on the backside of the switch had broken off too. i got a part number off switch 6759-325 but search only found a replacement of 6759-3251. will this switch work? any good suppliers? i also need a knob for the thermostat.
    thanks.
  2. PinnMcrack
    PinnMcrack Active Member
    1,276
    Aug 23, 2011
    Can you post some photos of this switch? front and back side of iy?
    If it is the same as mine, I had to go way outside the box and order something I will have to mod.
  3. jlynn58
    jlynn58 Active Member
    2,908
    Jul 9, 2011
  4. pafree
    pafree New Member
    49
    Jan 17, 2013
    i will get pictures but it is similar to the one in the link with the four wires but the knob shaft is longer. here is a picture of the one if you a the 1 on the end of the part number.
    i am sure i could figure out the wiring on the new style switch (not to bad at that stuff) but was not sure if there was a better to order or get.
  5. PinnMcrack
    1,276
    Aug 23, 2011
  6. meg1330
    meg1330 New Member
    Aug 14, 2017
    How did you fix it, I have the same part number and can not find a replacement
  7. tfischer
    tfischer Well-Known Member
    I wouldn't expect an answer, as the original poster hasn't been on the forum since 2014
