A-Frame solar install
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by Carlsbad, Jul 9, 2017.
  1. Carlsbad
    Carlsbad Member
    135
    Aug 19, 2014
    IMG_2225.JPG IMG_2226.JPG IMG_2228.JPG IMG_2227.JPG Pics of my solar install.
    Renogy panel is attached to roof with VHB on aluminum L channel.
    Wire moulding is standard Lowe's stock.
    Inlet is trolling motor charge set with plenty of Dycor.
    MPPT controller.
    300W Suresine powers a dedicated GFI outlet for laptops and small TV. It will put 500 watts continuous without a problem. I like it because unlike the big inverter it has no fan. It draws almost zero amps in standby. No noise.
    DiamondGirl and rabird like this.
  2. CO Hiker
    CO Hiker Active Member
    238
    30
    Dec 6, 2015
    Colorado
    Carlsbad, what factors made you choose the components you installed?
  3. Carlsbad
    Carlsbad Member
    135
    Aug 19, 2014
    I did some research first, then chose the best products I could source from Amazon. I did buy some misc. parts local as needed.
  4. ~erik~
    ~erik~ Active Member
    285
    40
    Jan 19, 2015
    North Georgia
    Your roof looks almost identical to mine!
    I've got a 150w Renogy panel, MPPT controller, and a Trojan battery made for a floor scrubber. So far I've been happy with the results, I think you will be too.
  5. Carlsbad
    Carlsbad Member
    135
    Aug 19, 2014
    Nice camper!
