AC not cooling.
Discussion in 'Heating / Cooling Systems' started by scamperman, Jul 11, 2019.
  1. scamperman
    scamperman Member
    62
    Aug 17, 2008
    Ohio
    Has anyone tried to put a window AC unit in there pup? The one that was in my pup died and i figure try a window unit. well took old unit out got the window unit in and fired it up started to cool then started blowing hot air.
    I have a 1998 Skamper and the AC in in the side it isnt a roof unit.
    And if i take window unit out and plug it in it cools real good just not in the pup.
  2. eoleson1
    eoleson1 Well-Known Member
    2,111
    591
    Jul 5, 2011
    Macomb County Michigan
    How is the unit mounted in the pop up? Window units need to be 90% outside and 10% inside to work properly.
  3. scamperman
    scamperman Member
    62
    Aug 17, 2008
    Ohio
    ahhh ok i have it slide up to were the face is flush with the cabinets. wonder if i put a fan in there with it if that would help?
  4. eoleson1
    2,111
    591
    Jul 5, 2011
    It would help. Maybe not enough, but you could try it. Those things generate a lot more heat than they remove.
    xxxapache likes this.
  5. WrkrBee
    WrkrBee Well-Known Member
    1,935
    726
    Look at the installation directions. The camper install should mimic them. Some Aliner owners have made theirs removable.
  6. PopUpSteve
    PopUpSteve Administrator
    18,563
    1,410
    Dec 22, 2002
    Malvern, PA
    Actually, the A-Line uses a window style unit on their camper which have or are able to have AC.
    I have seen standard PopUps where the owner has cut a port into the back panel (one side of the spare tire) for a window AC unit. I would however be concerned about putting that much weight aft of the axle. I've also have seen where people modify a section of canvas so that the AC unit can stick out between canvas panels.
    Whatever you end up doing, I would keep the option to remove the unit for cooler weather camping.
