Adding electric brakes...bought wrong parts?
Discussion in 'Tires / Brakes / Bearings / Axles' started by barrientosbunch, Mar 6, 2019.
  1. barrientosbunch
    barrientosbunch New Member
    28
    Feb 23, 2019
    What else do I need to buy? We need to add something to our TV to allow the brakes on the pop up work when the TV slows and stops. We ordered this: Universal Installation Kit for Trailer Brake Controller - 7-Way RV and 4-Way Flat - 10 Gauge Wires through etrailer. My husband says I ordered the wrong thing. Can someone keep me out of the doghouse?
    We have a 4-way flat, but the Starcraft has a 7 pin. Husband is an electrician by trade and wants to do this himself. He said we need a "controller". Which one do we get?
    Thanks for ANY help!
  2. PopUpSteve
    PopUpSteve Administrator
    17,821
    922
    Dec 22, 2002
    Malvern, PA
    Yup, you need a break controller.
  3. barrientosbunch
    28
    Feb 23, 2019
    Where do I get one? Any suggestions? We are newbies to this adventure.
  4. tombiasi
    4,745
    565
    Same place you got the other stuff.
  5. PopUpSteve
    17,821
    922
    Dec 22, 2002
    Malvern, PA
    Etrailer! They have a lot of info to help you pick the correct unit for your TV & Camper.
    barrientosbunch likes this.
  6. kcsa75
    kcsa75 Well-Known Member
    1,987
    775
    Sep 9, 2013
    Kansas City
    I would suggest you call eTrailer. They should be able to get you lined out with everything you need. [:)C]
  7. jmkay1
    3,905
    909
    Just throwing this out there in case I misread your message, but if your car has the 4 flat pin this will need to be changed to a 7 pin in order for the breaks to work also. The 4 pin connector will not have the break line wire needed. I’m not sure what will be needed to change it to the 7 pin I believe there were extra wires that would need to be run all the way back. Then once you get your. Tow vehicle connector changed then you will need a break controller in order for the breaks to operate when you apply yours.
    barrientosbunch and Raycfe like this.
  8. Sjm9911
    2,327
    886
    A breakaway switch and a battery for the pup is a good idea also.
  9. GatorChamp44
    GatorChamp44 Active Member
    118
    27
    Mar 16, 2017
    theseus likes this.
  10. Toedtoes
    Toedtoes Well-Known Member
    998
    616
    May 28, 2018
    I got the P2 on recommendation of my boss. They have different ones in various work trucks and he said he liked the ease of use of the P2 best and it works great.
  11. barrientosbunch
    28
    Feb 23, 2019
    What is the different between Tekonsha P2 and P3 Electronic Brake Controllers?
  12. Toedtoes
    998
    616
    May 28, 2018
    From what I can tell, the p3 offers five saved settings so you can tow different trailers. And it offers different customized boosts - the p2 only has electric over hydraulic. That was just a quick read so I may have missed something.
  13. theseus
    theseus Centerville, OH
    2,624
    290
    Feb 6, 2007
    Centerville, OH
    The only difference between the P2 and P3 is the screen and the P3 can store different settings for different trailers.
    I have had P2 for over 10 years and love it. What ever you get, DO NOT get a time-based controller. Proportional only please...
