Advice for setting up on wooded land
Discussion in 'Boondocking' started by Toby Gardner, Oct 19, 2017.
  1. Toby Gardner
    Toby Gardner New Member
    Oct 19, 2017
    Hi
    I am new to the world of pop up camping and to this forum. I recently purchased a 1988 Jayco 806 (8 ft by 7 ft footprint) in good condition to put on vacant land I purchased in upstate New York. The land has a slight slope and is lightly wooded (see pic). The previous owner of the pop up said I should build a platform to keep the camper off the ground. This is on a dirt road that is not passable from Dec through March due to snow so it would be left in the open Just curious about suggestions for properly setting up a camper in the woods and also suggestions for protecting it during the winter months on the mountain. Thanks.
  2. NMroamer
    NMroamer Active Member
    257
    62
    Apr 21, 2016
    Albuquerque NM
    I hope that you do not plan on leaving it open during storage.
    Pop ups are not made for extended periods being open.
  3. tenttrailer
    2,615
    94
    Jul 18, 2013
    Thornville, OH
    my big concern would be the snow load on the roof
  4. xxxapache
    2,162
    377
    Even closed up, a tree or branch will fall on it sooner or later. I suspect if the mice don't get it, the vandals will.
    With that said, there is no need to build a wooden platform. Just put some boards or pavers under the tires.
  5. jmkay1
    2,817
    343
    First I got to say what a beautiful piece of property. If the camper is to serve as a cabin in the woods I agree about putting something under the tires. My camper is stored in a grassy field and in the spring it sinks into the ground unless I spread the weight. My worry about wood blocks is it could disintegrate and get "buggy" over time. Campers can be stored out in the elements assuming the roof has been well maintained and its shut tight. What you haven't mentioned is how accessible this property is or how often you will visit. The biggest worry I see is if your area is prone for big heavy wet snows you may need to visit to brush the snow off. A pop up roof can only handle so much weight. Now trees may provide some protection from the snow, but could also pose a problem with broken tree limbs. Being in the woods you will need to make sure there is not a single gap for critters to crawl in. Perhaps put some other critter deterant. Make sure all stabilizers are up and stowed to prevent easy entrance for critters. Cover all vents,etc when your not visiting. It should be ok as long as you visit fairly frequently to ensure things are still solid. Being in the elements caulking can break down so you may need to do more maintenance to ensure a leak proof roof. My camper is stored in a field for storage, but fairly easy for me to visit it. the winter months I don't get out there as often, but do need to worry about snows. Good luck.
  6. Arruba
    Arruba Active Member
    152
    35
    Nov 28, 2014
    Central Oregon
    Pavers or concrete pads to park it on. If it staying in the same place then pavers or pads for the stabilizers/jack too.
    Snow shed to put it under when you are not using it
    Better yet, a full shed to put it in when you are not using it
    Truth is your idea is not totally out of the question. My Viking was purchased from a family who used it like a summer/weekend cottage. They kept it at a private lake development. Think trailer park in the woods. They had a 3 sided shed they kept it and their boat in. When they used it they just pulled it forward onto the pad and popped it up. Before me it was maybe used a 1000 times and only traveled maybe 30ft from storage.
    Best of luck with your endeavor
  7. roybraddy
    roybraddy Well-Known Member
    1,289
    271
    Mar 23, 2016
    King George, Virginia
    I think I would most definitely put up one of the Carport metal structures...
    You might want to check-in with the local county folks on what is allowed for land like this. I know here in Virginia there are all kinds of rules/permits for doing somthing like this. Our county has laws against living in a Trailer House except at trailer parks etc... Then there is what to do about the sewer. Can't just dump that on the ground... One guy I know here wanted to install an Power Pole in the middle of his country land and had all kinds of problems getting a county permit to do that. He was eventually wanting to build a house on his land and wanted to have the power pole up with 120VAC available at the pole to use first. I don't know if he ever got the permit to do that or not...
    Just saying it might be a good idea to check-in about those things before getting a bunch things purchased and then find out the county won't issue a permit to use it...
    We used to do all kinds of thing back in the 50s and 60s along this line. Now they all want the almighty $$$ and issue use permits etc..
    You also can't put up a garage here by it's self in King George County with no house and live in it...
    Roy Ken
  8. Toby Gardner
    Oct 19, 2017
    Thank you so much for all these replies and advice, especially regarding snow load. The popup would be stored closed and would not be accessible for 4 or 5 months so perhaps I will store it somewhere closer and then build a shed, as several of you suggested. But I wanted to ask you guys: would a tarp kept above the trailer and angled not work? I would not wrap the camper in the tarp but would create a ridgeline to allow airflow and snow to fall off?
    Luckily this is in an area where campers are permitted to stay on land year-round. You just can't live in it full time. Yes, this is very much my "cabin in the woods" before I have had a chance to build an actual cabin!
    Thank you all again.
  9. tenttrailer
    2,615
    94
    Jul 18, 2013
    Thornville, OH
    The tarp would be a good idea and if you could angle it. Popups for the most part are not built for a lot of load on the roof.
  10. 1380ken
    1380ken Well-Known Member
    1,527
    182
    Nov 7, 2013
    Mass
    I Hate to say it but you would be much better off selling the pop up camper and buying a hard sided camper. The advantage of popups is that they are easy to tow and store. For a stationary camper a regular camper would be much better.
    BelchFire likes this.
  11. eoleson1
    eoleson1 Well-Known Member
    1,416
    169
    Jul 5, 2011
    Macomb County Michigan
    You could do everything, or you could do nothing. How long do you want the camper to last? Popping it up in the spring and folding it back down in the fall would provide the shortest lifespan. Leaving it folded when not in use would extend it's life. Putting it on a platform/slab would reduce the amount of rust that forms on the underside. Putting it under a roof when not in use would protect the roof and make it last longer. Doing all of the above will protect it from moisture, rain, snow, and falling branches, but there's still the prospect of critters getting into it. You could go as far as building a garage to store it in, but at that point, why not use the garage as a cabin.
    It all depends on the amount of work you want to do. If it were me, I'd put some pavers under the wheels, fold it up when not in use, and hope for the best.
  12. nineoaks2004
    3,181
    532
    Graceville, Florida
    Make sure it is tilted front to back for water to run off ad make sure all holes for bug entrances are secured. The tarp idea might work if it is a heavy tarp, those cheap one would probably not hold up well. A shed like pictured by roybrady would probably be the best long term answer. Good luck and Happy Camping
  13. rover rob
    rover rob New Member
    Feb 5, 2018
    living in upstate ny I would not recommend it. the snow fall here can easily be 4-5 feet which would cave in the roof. I have seen tractor trailer roofs buckle over the weight if not removed fast enough. good luck
  14. J Starsky
    J Starsky Active Member
    147
    76
    Aug 3, 2017
    Park it on pallets - level those out first. Build a little deck with pallets.
    Build a burning barrel if you hate that idea.
    Buy green treated lumber, start over again...
  15. Bowman3d
    Bowman3d Active Member
    602
    121
    Apr 13, 2015
    LaLa land
    This is my cabin in upstate NY. I didn’t make it up to shovel the roof off...
  16. rover rob
    Feb 5, 2018
    ouch
  17. jnc
    Hate it when that happens!!
  18. Jim_Rockford
    Jim_Rockford Member
    78
    Apr 7, 2014
    Just goes to show , you do not own your land..you rent it from the government.
  19. roybraddy
    1,289
    271
    Mar 23, 2016
    The local counties around here sure has different rules on what you can do and can't do. I guess there is some rhyme and reason for it all... We can park our RVs at our home locations here in this county but we can't live in it. Won't allow you to hookup permanent water and sewer it seems...
    I recently had to go thru several visits to the county office just to install a second ditch entrance on the adjoining road on the back of my property. Just wanted to put in three lengths of concrete culverts to drive over... Finally got it down but it got inspected by the county at least three times while I was getting the culverts in the ground... That's when you find out 12-feet from the edge of the road doesn't belong to you... Of course I had to purchase the culverts however to put on their property.
    My neighbor went through the same drawn out process adding a new patio at his back door... geesch...
    The nice county inspector drives a nice county truck and walk around with clip-board. Certainly doesn't have any dirt under his fingernails hehe...
    Roy Ken
  20. Jim_Rockford
    Jim_Rockford Member
    78
    Apr 7, 2014
    and people ask me if I am going to buy another house..lol not on your life.
