air condtioner leaks rain water
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by HAWKEYE71, May 18, 2017.
  1. HAWKEYE71
    HAWKEYE71 we love to camp
    Dec 22, 2015
    Need to troubleshoot why my freedom popup leaks rain water onto the floor of my camper. How do i fix this issue? I'm on a Limited budget.
  2. xxxapache
    1,762
    191
    You can try tightening the mounting bolts and see if there is enough give left in the gasket for it to compress and make a seal. If that doesn't work, you need to pull the AC and replace the gasket.
    theseus likes this.
  3. theseus
    theseus Centerville, OH
    2,143
    99
    Feb 6, 2007
    Centerville, OH
    ^^^x2
    What he said...
  4. Customer
    Customer Well-Known Member
    2,218
    80
    Jun 5, 2014
    Remove the plastic cover inside the RV. You will see four bolts which clamp a foam gasket between the A/C unit and the roof. Tightening the bolts a little might work or you may have to replace the gasket.
  5. rsizle
    rsizle Member
    53
    Apr 17, 2014
  6. HAWKEYE71
    Dec 22, 2015
    Thanks 4 the information.i will check this out on monday
