Any advice on cutting off a hitch pin.
Discussion in 'Miscellaneous Repairs & Maintenance' started by jim1999, May 1, 2010.
  1. Big_kid
    Big_kid Virginia Beach, VA
    2,208
    Jan 13, 2008
    I've seen them rusted in to where they were not coming out, period.
  2. Alter Ego
    Alter Ego Member
    147
    Dec 5, 2009
    Park behind the stuck ball mount no more than 10 feet with a good winch. Hook the winch cable to the ball mount hole. (It is not safe to connect directly to the ball because the winch exceeds the rating of the ball.) Put some tension on the winch. Bang the ball mount right and left with a 4 lb sledge.
    That same loose fit that made your hitch rattle all those years will provide just enough wiggle room to shear the rust loose. Just keep banging and pulling. You did pull the pin out first, right?
  3. bflentje
    bflentje Member
    296
    Aug 24, 2009
    ditto. I never leave mine in when not in use but not because I am worried about theft (knock on wood).
