Axle Flip, Shocks???
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by ricksadventures, Jan 2, 2019.
  1. gladecreekwy
    379
    353
    Sep 25, 2016
    Ha! I thought that when I posted it. It’s one of our favorite spots and it’s the best pic of it. You come to my neck of the woods and I’ll tell you exactly where it is.
    Overland likes this.
  2. Dingit
    Dingit Active Member
    546
    184
    Mar 8, 2017
    If you put LT tires on your trailer, do you try to get the same size as your TV so you have extra spares? I think Jeep guys used to do that...
  3. gladecreekwy
    379
    353
    Sep 25, 2016
    If they were the same size. My TV is on 35”s
  4. Overland
    Overland Active Member
    158
    84
    May 1, 2013
    Bristol, Pa
    Tough to get a matching tire size when tucked under the camper vs on the outside and fendered.
    I run a 31" AT on my Jeep, I managed to squeeze a 225/75 (28") under the camper but it took lifting camper a bit more than i'd have liked. Considering cutting in new fender wells come spring to bring it down a bit.
    Keep in mind also, an LT tire is illegal in some states. I found that out here in Pa when I went to get a set mounted.
  5. JimmyM
    JimmyM Well-Known Member
    2,063
    378
    Jun 5, 2014
    Franklin, MA
    Tires and springs will not control bounce. Shock absorbers dissipate the energy of the bounce. Based on your description, shocks would definitely help. Try to get shocks for a small car. Shocks are tuned to the spring rate and mass of the vehicle they're for. Putting big offroad shocks on it will probably just snap off the studs. Too stiff. Maybe the rear shocks off something like a Subaru Crosstrek. Small car, decent suspension travel.
  6. WrkrBee
    WrkrBee Well-Known Member
    1,166
    410
  7. Turbulent
    Turbulent Member
    60
    Jan 2, 2018
    I'm going to try this axle flip mod. I hate that i nearly bottom out in my driveway. Scraped the my bottom of my lift crank pole on the first time out. Im a noob in theses matters and have a few questions:
    • Can I keep the original tires? im at 13" (i think)
    • Will I have to use blocks when I lower the stabilizers?
    • Will the axle flip allow me to install larger tires?
    • Are there any mechanical/engineering cons to doing this?
    Thanks!
  8. joet
    3,719
    563
  9. gladecreekwy
    379
    353
    Sep 25, 2016
    You can keep your tires but the advantage to the flip is you can run bigger ones. You may need blocks depending on the length of your stabilizers and the terrain. We needed another step stool. My advice is to run the largest tires possible. We lifted ours 15 years ago and have had no issues.
    Anthony Hitchings likes this.
  10. Turbulent
    Turbulent Member
    60
    Jan 2, 2018
    thanks, everyone.
    I keep reading and watching videos about this mod and im seeing mentions of possible welding in some cases and different axle types.
    I'll have to check under the pup today and snap some pics
  11. joet
    3,719
    563
    If you have brakes, your spring perches must be welded on the axle. Without welding them, when you apply the brakes, the axle will rotate.
  12. Turbulent
    Turbulent Member
    60
    Jan 2, 2018
    I do have electric brakes. Welp, looks likes i cant do this mod without any help. i can barely glue macaroni on maps
  13. GrueMaster
    GrueMaster Active Member
    145
    41
    May 22, 2013
    Saint Helens, Oregon
    Yea, that might be a problem best left to the experts. :tongue:
    This spring, I will look more into it. I have a 2002(?) Coleman Timberlake with e-brakes. My mechanic said he couldn't do it but the reason he gave didn't sit right (said they wouldn't work upside down). Since I have the manufacturer's manuals for every piece that was used to build my trailer (including one for the axel), I'll see what they say.
  14. WVhillbilly
    WVhillbilly Well-Known Member
    493
    340
    Jun 6, 2018
    WV
    http://timbren.com/axle-less/
  15. SteveP
    SteveP Well-Known Member
    1,123
    235
    He's right. Plus you have a cambered axle, and if you simply flip you'll reduce your cargo weight and have to replace the tires every season.
    Look on the Dexter website for a spring over axle conversion kit, which includes new spring perches that have to be welded to the top of the axle.
  16. BillyMc
    BillyMc Active Member
    473
    150
    Mar 25, 2018
    If you put a straight edge on your axle you will probably find that it isn't exactly straight. The proper way is to move the perches to the top of the axle and mount the axle under the spring. This keeps everything in it's proper orientation.
  17. Anthony Hitchings
    Anthony Hitchings Member
    42
    Mar 2, 2019
    no need to weld if you use the Dexter kit for Spring-over-axle (SOA) kit. Though they recommend it (that's their risk manager talking)
  18. Anthony Hitchings
    42
    Mar 2, 2019
    I will likely try the spring over axle conversion as we do go off road on some of our trips, such as in Cedar Mesa, Escalante, North Rim of Grand Canyon etc. The conversion is reversible and affordable, so why not.
  19. theseus
    theseus Centerville, OH
    2,624
    290
    Feb 6, 2007
    Centerville, OH
    I used the dexter kit. I then we took a trip to Yellowstone. When I got back I had to rotate the axle back just a hair, to get the tires to have the right camber. Make sure you check that or you’ll have weird tire wear.
    No I didn’t weld them.
  20. Anthony Hitchings
    42
    Mar 2, 2019
    I am thinking that the camber thing is highly over stated. For example, the VW bug had a large camber on its rear wheels and seemed to do OK. I see all kinds of independent suspension on the rear with very visible camber, including name brand cars. It' can't be such a big problem.
