Bag awning question
Discussion in 'First Time & New Camper Owners' started by Dan Wilson, Feb 19, 2019.
  1. Dan Wilson
    Dan Wilson New Member
    21
    Jan 30, 2019
    Appleton, WI
    Do you unzip the awning bag and pull the guts out before you raise the top or after? Looks like a difficult reach when it is up all the way.
  2. soft 17
    soft 17 Active Member
    241
    103
    Mar 14, 2017
    San Luis Obispo
    Yes we do.
  3. Fuzzy Bear
    Fuzzy Bear Active Member
    475
    65
    Mar 3, 2004
    Norwalk CT
    I usually raise the top a couple feet, then unzip the bag then finish raising the roof.
  4. MileHigh
    MileHigh Member
    358
    Jul 18, 2012
    I also raise the top a few feet and then get the awning out. It's difficult to get the zippers undone when the roof is raised all the way unless you are tall.
  5. Dingit
    Dingit Active Member
    546
    184
    Mar 8, 2017
    And do this at home before you go anywhere so you don't have to figure out how to stuff an awning inside a popup because it detached from the rail on your first attempted deployment and it won't fit into the campground dumpster. :)
  6. GreyFox
    GreyFox Active Member
    415
    148
    Oct 10, 2018
    S Ontario
    JWeible likes this.
  7. jmkay1
    3,905
    909
    Before for me as well. Just became a problem if a bad storm was brewing and I needed to put the awning away before damage.
  8. tfischer
    tfischer Well-Known Member
    3,092
    634
    May 21, 2014
    I'm tall. I usually unzip the bag when down, but not untie the awning (ours has ties inside, not sure if they all do). Then I set it up the rest of the way once the camper is set up.
    Sometimes I forget and can still unzip it if I have to. Standing on the step helps but isn't necessary for me.
  9. BikeNFish
    BikeNFish Well-Known Member
    2,014
    1,138
    Apr 24, 2017
    Maplewood, MN
    When I don't forget to do it (which is most of the time) I take the awning out before the roof is raised all of the way up. It is actually the manufacturers recommendation to take it out before raising the roof.
  10. Dingit
    546
    184
    Mar 8, 2017
    Why do you raise the roof a few feet before unzipping?
  11. BikeNFish
    2,014
    1,138
    Apr 24, 2017
    Maplewood, MN
    It's easier to handle when it is up a bit because a half unrolled awning is easier to handle when the roof is being raised the rest of the way than a fully rolled up awning before you start to raise it. <---wordy!
  12. BillyMc
    BillyMc Active Member
    473
    150
    Mar 25, 2018
    I raise the roof until the awning is about head high and unroll the awning, then zip on the screen room. Finish raising the roof and setting up as normal. Reverse when packing up.
  13. Dingit
    546
    184
    Mar 8, 2017
    Woah. I have the feeling you guys are way taller than me. My awning is already over my head before doing anything (except when it's laying in pieces on the garage floor)...
  14. GreyFox
    415
    148
    Oct 10, 2018
    S Ontario
    Difference is you have a high wall camper.
    BillyMc likes this.
  15. Sneezer
    1,320
    377
    I raise mine a bit as well. I am lucky in that mine had Velcro from the factory, so it won't spill out. Poles travel in bags in the front trunk though. We unroll, install the rafters and legs, then adjust as the roof goes up. If the screen room is going to be used we try and install it at the same time since the side rafters have to thread into a sleeve on the screen room.
