BAL leveler size question
Discussion in 'Leveling Your Camper' started by Amblix, Oct 17, 2018.
  1. Amblix
    Amblix New Member
    Sep 11, 2018
    Hi Everyone,
    Looks like I may have jumped the gun when purchasing a BAL leveler. It says for 12"-15" wheels. That said, I put it around mine just to see and it 'looks' like it would work so I can't tell if they mean for 12"-15" with tire or wheel only? I think my wheel is only 8"
    Here is a pic for reference. Right as it started to raise the PUP, I stopped as I don't want to cause any damage if this is not the way it should be.
  2. jnc
    3,897
    1,140
    Oct 1, 2014
    South Central New Hampshire
    You have it setup right but your tires are a bit small. This is fine because you will almost always be able to slide it under your tire. I have 15" tires and it can be a challenge at times. I would suggest that you bring along a small piece of wood or 2 to put in between the jack & the Tire to take up some slack.
  3. Raycfe
    14,136
    988
    Just add some wood spacers to the pads for the tires ....... will work great.
  4. Matt Benoit
    Matt Benoit Active Member
    382
    210
    Jul 30, 2017
    Warren, MI
    I have 12in wheels and needed to add a piece of wood to one side of the ball leveler. You will likely need wood on both sides. 20180517_174522.jpg
  5. Amblix
    Amblix New Member
    Sep 11, 2018
    Wow! Thanks everyone!
