Battery hook up
Discussion in 'Wiring' started by Southpaw, Sep 13, 2018.
  1. Southpaw
    Southpaw New Member
    21
    Sep 7, 2018
    228D03A3-683A-4173-BA8F-FEABCC7C23C0.jpeg 069AE369-223B-4B6C-AD36-2EE32D404301.jpeg EF2087BB-C26F-497D-A61C-F898DE9022C4.jpeg 228D03A3-683A-4173-BA8F-FEABCC7C23C0.jpeg 069AE369-223B-4B6C-AD36-2EE32D404301.jpeg Hi, I have a new to me 2002 palomino pinto sg. It doesn’t come with a battery hookup but does have the converter and will run 12v off of my tv. I would like to hook up a battery to it but I don’t want to wire it wrong and I can’t find a wiring diagram for it. The only wire that goes from the tv connection to the converter is a black wire (pictured) and it has a connection near the front of the pop up box (also pictured) so I am pretty sure that is where my positive lead from the battery hooks up. But do I connect the wire coming from the tv back into this connection so that it also charges the battery I install? And then just ground the battery with a white wire to the frame? There is a green wire running with the black one but it doesn’t go to the converter. Any help is appreciated
  2. joet
    3,650
    551
    you are correct Black is positive and white is ground
  3. Southpaw
    Southpaw New Member
    21
    Sep 7, 2018
    OK so do I hook up the black wire coming from the 7 way to the battery and then to the black wire going to the converter? And then just ground the battery directly to the frame?
  4. joet
    3,650
    551
    And make sure everything is fused
  5. rabird
    6,347
    167
    TX
    my battery + was hooked up as below, a fuse at the batt + and spliced into the TV/converter line, the batt neg attached to a chassis clamp under the PU with other chassis commons.
  6. Southpaw
    Southpaw New Member
    21
    Sep 7, 2018
    Ok thank you, that’s how I thought it would go but I didn’t want to screw anything up of o did it wrong. I appreciate it
  7. Raycfe
    13,941
    939
    YOU SHOULD BE FINE...
