Bed Slide ramp
Discussion in 'Slide-Outs / Bunkends' started by squid, Mar 15, 2017.
  1. squid
    squid New Member
    24
    Jul 7, 2011
    Question about properly sliding bunks in and out? When sliding bunks in, does the end of the bed(end with strap) go over the bed slide ramps(white Teflon squares) and set behind the bed slide ramp which allows the entire bunk end to set on top of end wall instead of setting on top of the Teflon bed slide ramp. I just want to make sure I'm doing this right and that I'm not putting undue stress on my bed rails. Thanks!!
  2. Natureangel
    704
    Feb 28, 2016
    Illinois
    On mine it pushes past the outside lip when I'm taking it down.
  3. Halford
    Halford Active Member
    your bed rails bend down or straight? (someone may have forgotten to put bed support poles before getting on it once or twice thus bending the rails)
    I carefully pull and push in bed if you push the center of the outside end of bunkend.
  4. squid
    squid New Member
    24
    Jul 7, 2011
    My bed rails tend to bend in from the top. Not much , but enough to notice. I noticed this and this is what caused me to raise the question. I'm not the original owner but it has been taken care of. I'm going to raise the top pull bunk end out just a little, so the bunk edge sits on top of the Teflon slide and see if the rails are still leaning in and the top closes. Thanks
  5. squid
    squid New Member
    24
    Jul 7, 2011
    My wife says I over think things, or as she puts it," I worry too much about things". But after 30 years in the Navy, in the Submarine Service, I guess I can't get it out of me. One little thing can lead into bigger things.
  6. Halford
    one little bend can get the bunkend stuck until the rail is mended.
