Bike Rack - Palomino Popup Pony 280 - year 2010
Discussion in 'Cargo Carriers / Bike Racks / Other Storage Option' started by aardvark, Mar 14, 2019 at 9:30 AM.
Tags:
  1. aardvark
    aardvark Member
    31
    May 30, 2016
    Does anyone have a popup like I have, or one form the same family or similar construction? (I think many or most of the Forest River models have similar construction).
    The roof is all fiberglass, and I don't want to drill into it
    The tow vehicle is a 2013 Subaru Forester. It would be tough to squeeze anything in between the tow hitch and the tongue. The roof of the car usually has as many as three whitewater kayaks when I go some place, so I'd prefer not to have a car roof mount if possible. I could move the kayaks to the camper roof, and tie them on top, but the roof mount works better, and once i arrive, will carry the kayaks on the car roof.
    I saw a spare tire bike rack listed, and am not sure how well these work. Here's one example:
    https://www.amazon.com/Yakima-8002599-SpareRide/dp/B0171A6MSU?tag=gearingout-20&psc=1
    Does anyone have experience with these, and if so, what model/manufacturer do you prefer?
    Does anyone have another alternative?
  2. Snow
    9,398
    633
    Anything added to the back of the pup will reduce the tongue weight and induce sway. Only way to counter act the sway would be to add the same amount of weight to the tongue, which will increase your tongue weight and any weight added to the pup will increase its weight (and at the sametime lowering it's CCC) .
  3. aardvark
    aardvark Member
    31
    May 30, 2016
    Will a rack like this plus a 30 pound bike be significant, or not? Will two bikes (60-70 pounds plus the rack weight) induce sway?
  4. Snow
    9,398
    633
    Yes..
  5. giadiep
    giadiep Active Member
    352
    136
    Sep 5, 2015
    Syracuse, NY
    It looks cool, but would it leave you enough room to still carry the spare tire back there? If you try it, you can just move all your heavy stuff that you normally carry in the pup forward to counterbalance (like a full cooler).
  6. Rusty2192
    Rusty2192 Active Member
    702
    209
    Jul 30, 2014
    Kentucky
    The spare tire on most pups is just bolted to the wall and most likely wouldn’t support the weight of bikes. I’d be really worried about it ripping right off the back of the pup.
    Your best option is probably to mount the bike on the roof of the TV and squeeze as many kayaks as possible on there too and put the rest on the pup. You could always upgrade to longer cross bars and maybe fit it all on the TV.
  7. Buckmaster81
    Buckmaster81 New Member
    28
    Feb 27, 2019
    Long island NY
    How about front mount tow hitch for your car... then put a bike rack on that.
  8. jmkay1
    3,905
    909
    There was a post I saw on here where someone bolted bikeracks on a long piece of wood or two. That expanded across the roof and was strapped down by ratchet straps and another strap through the back tires of the bikes. I have not tried it myself but it looked promising. Check out the bike rack section I believe you may find that thread. Bikes over the camper tires will be the safest. If you are able to keep the pressure points on the edges of the camper that would help as well.
