1. peter moyes
    peter moyes Active Member
    129
    28
    Feb 6, 2018
    ,hello campers and fisher people...i have a 2000 coleman sedona ,,i also have a 12 ft aluminum boat ,it weighs i think like 450 lbs ,,,i am sure i cant put that on a roof rack ,,the others mounted to the frame look expensive ,,any ideas to make something with pvc pipe ,front and back ?or is it a crazy idea lol
    also i want to put back up lights on it for parking at night ,,how would i wire them up ..i bought a big orange l.e.d.battery operated light ,with a very strong magnet .just in case of break down at night ,,2 of these ,with clear lenses would work good to ...,i am a newbee lol
  2. jmkay1
    4,046
    986
    Can't help you much, but the biggest question is, would 450 pounds put you overweight on your axle? Before you even consider this, I suggest to weigh your camper as is ready for a trip less the boat and see exactly where you stand. Many will be surprised how much heavier they really are.
    Personally I don't think PVC pipe could hold up under the weight of the boat much less wind hitting it when driving.
  3. nineoaks2004
    6,277
    2,345
    Graceville, Florida
    450 lbs is a lot of weight, maybe a lighter boat, if you do get a rack you have to get the boat up on the rack. I use a ladder rack on my Pickup for my yak or solo canoe either of these weigh less that 60 lbs. and as stated I do not think PVC would be good as a rack
    I also do not think that 450 lbs on the top of the PUP would be w good idea either as it would probably put a heck of a strain on the axle and tires. Good luck and Happy Camping
  4. friartuck
    friartuck Well-Known Member
    2,808
    84
    Nov 1, 2007
    Perry, MI
    Maximum roof load on a Coleman/Fleetwood is 300lbs closed, 150lbs open including AC. A 450lbs boat is way over your roof limit.
  5. peter moyes
    129
    28
    Feb 6, 2018
    yes i agree thank you
  6. Sjm9911
    2,665
    1,063
    For just tooling around look for a cheapo blow up kyack. I have one verry happy with it. While i havent used it for fishing, if its just you there is plenty of room. Mine has been going strong for over 10 years now. Cost of maybe 200 dollers.
  7. jmkay1
    4,046
    986
    . Kind of along the same lines, sea eagle makes an inflatable 4 person boat complete with engine. Although that can be pricey new.
  8. Byrd_Huntr
    Byrd_Huntr Well-Known Member
    1,206
    243
    Jan 27, 2013
    Minnesota
    Unless your boat has a deck, it probably weighs about 250, still too heavy for a plastic rack. Unless you are experienced with wiring, I wouldn't tap into trailer or tow vehicle lighting systems which can be finicky. Just rig a temporary two wire cable that has alligator clamps and runs from your trailer battery (or cigarette lighter) over the top of the camper to the lights held to your trailer bumper with magnets. Take them off and stow when you get backed in.
  9. peter moyes
    129
    28
    Feb 6, 2018
    i have decided to sell my 12ft boat ,and get a zodiac or another good make like avon etc ,i saw one near me ..700 bucks ,the good ones are very expensive ,,but they are sweeeeeeeeet lol
  10. peter moyes
    129
    28
    Feb 6, 2018
    any other pup owners can give me advice on used inflatables ?seems to me zodiac and avons mercury are the best ..but pricey ,i have decided to buy a cheap used one ,,but a good name brand ,i will get 400 bucks for my 12 ft tinny its like new ...i got a sedona pup and had the idea of putting my boat on the roof ,but its way to heavy .................still looking for a used roof rack for my pup ...now winter is round the corner ,pups boats etc get cheaper ..
  11. Lagman
    Lagman Member
    67
    Sep 29, 2016
    Bucks County, PA
    I welded a rack together using 1 1/4” square tube. Comes apart like scaffolding just below where the bunks pull out. Had to buy a welder but it’s solid.
  12. nineoaks2004
    6,277
    2,345
    Graceville, Florida
    Looks good and also looks solid. Should work just fine, do not do as I once did, i had a yak /canoe rack I put on one, first time out I raised the roof, looked up and had an aw sh#@ moment, I had forgotten to remove the canoes off the roof, had to let everything back down to get my stuff off the roof, helped the learning curve tho as I never forgot again :) Good Luck and enjoy taking the boat along
