Boondock coffee solution
Discussion in 'I Smell Something Cooking!' started by Dan Wilson, Mar 4, 2019.
  1. generok
    generok Well-Known Member
    2,302
    429
    Feb 7, 2013
    Anchorage, AK
    Yup, been using a pour over for a few years now. Works great and very little cleanup.
    Arlyn Aronson likes this.
  2. nineoaks2004
    6,234
    2,325
    Graceville, Florida
    I have used on for years, one of the most used items back when I backpacked, I still use it when canoe camping, easy and I can make the coffee as strong as I want /need, my Cousin was amazed on our last canoe trip, he had never seen or used one, but is the proud owner of one now.
  3. BBQdave
    BBQdave Active Member
    101
    45
    Aug 31, 2016
    North Carolina
    When it's just me, I use a stainless steel Farberware percolator. It's well seasoned, great coffee!
    If there's a group of us, cowboy coffee :) I have a large stew pot, rolling boil for 3 minutes, toss in cup of cold water (to knock the grounds down) and your good to go. I usually let it rest for a couple of minutes after rolling boil and ladle out the coffee. Very smooth coffee and no grounds.
    Boiling coffee lowers the acidity, makes all the difference :)
    Buckmaster81 and arge like this.
  4. arge
    arge Member
    62
    Feb 27, 2018
    I do pretty often the cowboy coffee :)in my mug.
    Get the boiling water, a couple of tablespoons of coffee, wait a minute, add a bit of cold water and here we go.
    As a matter of personal taste, I don't like to boil the coffee as most of the flavors are gone. Just add coffee in the hot water.
  5. roybraddy
    roybraddy Well-Known Member
    1,849
    523
    Mar 23, 2016
    King George, Virginia
    We ended up with the CUISINART GRIND AND BREW Coffee maker. This uses coffee beans and will grind and brew a 10-cup carafe in about five minutes. This is the total time you need to brew the coffee. after it is poured up into the stainless steel carafe then it will stay hot all day long... Only consumes power for five minutes and completely shuts down power wise after that...
    My routine is almost the same everyday whereas I am running my 2KW generator each morning to re-charge my off-grid battery bank from its 50% charge state to it's 90% charge state in a three hour generator run time. While doing this I will make my fresh ground and brewed coffee for the day running off the generator.
    Google image
    This works out great for us. We bring along the same bottled water just for making coffee taste that we like.
    Of course out backup is the COLEMAN BLUE Stovetop perculator…
    Goggle image
    I also carry a MR COFFEE electric grinder to grind up my coffee beans and both setups come pretty close to our coffee bean liking... My duty 600WATT PURE SINE Power Inverter always ON setup runs the coffee grinder just fine when needed when off-grid...
    Roy Ken
  6. michaeltdyer
    michaeltdyer Member
    152
    Nov 26, 2012
    Denver Colorado
  7. Sjm9911
    2,611
    1,040
    Wow , not cheap!
  8. Fred1diver
    Fred1diver Active Member
    142
    46
    Sep 11, 2018
    Found the same one used for 40$
  9. TinyCamperPro
    TinyCamperPro Member
    63
    30
    Dec 27, 2018
    Thats a neat design but I agree with some of the others. We carry a small coffee press mainly because we found the pour over to be a little to weak as well. Just a small one we picked up on Amazon. Just boil the coffee on the coleman stove in the morning.
  10. David Blackwell
    David Blackwell Member
    41
    May 10, 2017
    San Diego, CA
    One of my favorite YouTube channels is Cowboy Kent Rollins. Aside from all of his great recipes and videos on cast iron/dutch ovens, he just posted an updated video on "How to Make Cowboy Coffee".
  11. Arruba
    Arruba Active Member
    244
    59
    Nov 28, 2014
    Central Oregon
    If it’s just me, a Melitta pour over. IMO, as mentioned previously the keys are the grind and HOT water. If it’s a group, I’ve got an old fashioned granite percolator. FWIW, my Jetboil came with a French Press plunger. Using a true French Press grind and a slow press, I think it makes a good cup o joe too.
  12. nhlakes
    nhlakes Well-Known Member
    620
    294
    Oct 15, 2011
    DE and NH
    We now use pour overs while in the camper, boondocking or not. Regarding water temp, we use this kettle (apparently not available at the moment) with a temperature gauge to indicate when it has reached the (what is apparently considered) the best pour over temp, and find it very convenient.
    https://www.amazon.com/gp/product/B01IR8K7Z4
  13. Arlyn Aronson
    Arlyn Aronson Active Member
    725
    238
    Jun 11, 2014
    Houghton MI
    We use this collapsible silicone drip for camping. Space is a premium for us and its much easier to clean that presses or other systems. We usually have limited water with us, so we simply throw the filter and grounds away when done, then rinse this cup out. We've tried all coffee making systems in the field and reverted back to this. We also grind enough coffee at home and bring it along.. I should add, we commonly camp in cooler temps so have a towel along we put over this cup to keep the heat in as it dripped out. Its a large enough a towel to keep the whole thing under it. Good coffee is what its about. [:D]
    https://www.amazon.com/Kuissential-SlickDrip-Collapsible-Silicone-Dripper/dp/B0051HEFAS/ref=sr_1_4?crid=2L3F1CN1KXP4J&keywords=silicon+coffee+dripper&qid=1554944125&s=gateway&sprefix=SILICON+COFF,aps,193&sr=8-4
  14. tenttrailer
    3,029
    233
    Jul 18, 2013
    Thornville, OH
    We do the stove top percolator.
