Brake controller and observation camera
Discussion in 'Road Safety Systems' started by mpotapa, Oct 26, 2017.
  1. mpotapa
    mpotapa Member
    Mar 11, 2014
    i currently have a Tekonsha Prodigy wireless brake controller. With my new camper I am getting a furrion observation camera. Both plug into the 12v cigarette lighter. I have two up in the front of my truck. Is there any issue using both these units at the same time?
  2. JPBar
    JPBar Well-Known Member
    Sep 22, 2016
    Would not think it would be.
  3. davido
    davido Active Member
    Jul 17, 2014
    This sounds strange. Your brake controller plugs into the cig lighter? How does it know when the brakes are being applied?
  4. megcabra
    megcabra Active Member
    You have to check it out, it really is a great new product! To me it is worth it just not to have to wire in a traditional controller in a TV you may only have for another year or so. Then go though the process all over again with a new TV.
  5. mpotapa
    mpotapa Member
    Mar 11, 2014
    I lease my vehicles so this saves me from having to install a break controller in a new truck every couple years.
    megcabra likes this.
  6. Sneezer
    Sneezer Active Member
    Check the amp draw. Are both outlets off the same fuse? As long a they don't overload the fuse and don't use the same frequency for transmitting then it should be fine.
  7. f5moab
    May 7, 2013
    Somewhere in Idaho
    The Tekonsha RF brake controller is NOT NEW. I used it on my 2013 Silverado and Hummer cause I didn't want to install a permanent one. It worked great and never had a problem with it.
    I'm assuming the hand unit pulls very little amperage so using both the camera and the hand unit on the accessory plug would be safe. If not it will simply blow a fuse.
  8. Sarahw
    Sarahw New Member
    Feb 17, 2018
    It's interesting but the system should plug into any std 12v and so they should work
