Camp Stoves
Discussion in 'Boondocking' started by Pirate_Popup, Dec 14, 2015.
  1. bob barnes
    bob barnes Well-Known Member
    1,363
    190
    Mar 26, 2017
    I purchased a dual fuel coleman for 1/2 of retail it was brand new carried it to Europe as there is no coleman fuel there!!
  2. bob barnes
    1,363
    190
    Mar 26, 2017
    I have a coleman 2 fuel car gas or white gas!!
  3. Arlyn Aronson
    Arlyn Aronson Active Member
    317
    32
    Jun 11, 2014
    We have about 4 white gas stoves. 3 of them are Coleman and the other is light weight one for Backbacking. Won't use anything else but a WHITE gas fueled one.
  4. xvz12
    xvz12 Active Member
    330
    106
    Apr 6, 2017
    New Plymouth, ID
    I have 3 Coleman 'suitcase' stoves, all of them date back to the early '60s, one of them looks like it had been thrown off a cliff at some point, but all run very well. Just got back from camping, where we were using the 3-burner one, along with a Coleman camp oven. I have several 'backpacker' type stoves, in butane, white gas & kerosene versions, which have been used on motorcycle camping expeditions, & i don't know how many various 'cabin' type stoves, again of pretty much all fuel varieties. Nowadays, the Coleman white gas 3 burner gets most of the work, about the only thing the propane stove in the PUP gets used for is to heat water for DW's morning cocoa. I do keep a backpacker model tucked away in the PuP, just in case....
  5. BirdsNest
    BirdsNest Active Member
    142
    32
    Jun 12, 2017
    Utah
    I have an RVQ stove that hangs on a bracket on the side of the PUP that handles most of the cooking duties if we aren't "going wild" and cooking straight on the campfire. The stove inside the trailer only gets used to heat water and other similar things that don't produce any smells that might be absorbed into the canvas. I'll probably eventually get a portable Coleman for extra cooking duties when needed, but for now this seems to work OK for us. The only time it has been a challenge so far was when I tried to do a 'real' breakfast with eggs, bacon, sausage, and pancakes. I had to cook those in shifts since there's no way it would all fit on the RVQ and I didn't want any of them inside the trailer.
  6. bob barnes
    1,363
    190
    Mar 26, 2017
    the best coleman I have is a single burner all fuel job that things hums on car gas!!!!
  7. Sneezer
    Sneezer Active Member
    672
    143
    I have a Coleman roadtrip that I adapted to run off the low pressure camper port. It works well, but it is not great at boiling water. When I have the stove grates on it takes forever to boil even a small amount of water. It excels at being used as a griddle with the griddle plates, and works well as a grill too.
    I also use an old Coleman white gas stove that works quite well, and a Coleman 3 burner eventemp stove. I really like this one, but adjusting the flame is a pita.
    Looking to move to a Camp Chef stove of some type.
  8. Eric Lamontagne
    Eric Lamontagne New Member
    May 23, 2017
    Cornwall, Ontario
    I use a 2 burner cheap 1lb bottle propane special with an adapter hose 5ft long to 20lb bottle.
    works great for all my needs and with my old rig (1979 bonair) didn't trust the propane so sat on the rack.
    new rig havent taken i out yet but has indoor outddor burner ( 1998 coleman sea pine)
  9. sleach
    560
    63
    May 17, 2014
    Having just lost a two burner Coleman liquid fuel stove to water damage over the winter, I went to Craigslist and found a good used three burner. Now we're really gonna be cooking!
    More seriously, I favor the liquid fueled stoves for their higher heat output and lower fuel cost. A stove that can easily be set up on a picnic table or folding stand or tailboard of the pickup is a must for us. That said, I must say the little one burner Coleman butane canister stove is a delight when all that is desired is hot water for coffee or instant soup.
  10. xxxapache
    1,895
    232
    I love my 3 burner liquid fuel. I picked a new one up at a Coleman outlet on clearance right before they discontinued them.
  11. Popiworks
    119
    Jul 22, 2014
    I just received a Primus Base Camp propane stove from Amazon. I ordered one from Amazon Warehouse and it arrived without a scratch and in good working order at half the cost. Windy here today and I was able to maintain a low flame without blow out. Looks promising.
  12. CamperLover
    CamperLover For evil to triumph, Good men do nothing
    128
    Jul 28, 2015
    I have it all. I camp in large groups. I use a smoker, camp chefoven, dual fuel stoves, grill, flat top. Camp Chef C-oven is the best bang for the money.
  13. Fbird
    Fbird Member
    78
    21
    Sep 10, 2017
    Ferndale MI
    I use a coleman 413b from the mid 40's. I don't boil water much. I think the temp control is better than propane and they work better in the winter time.
    xxxapache and kitphantom like this.
  14. ArizonaJoe
    ArizonaJoe New Member
    27
    Oct 18, 2017
    We have a Camp Chef oven and a Camp Chef Everest stove. We have 4 burners between the two of them and love them both.
  15. tombiasi
    4,094
    200
    I have this stove. It's high pressure and is just as hot , if not hotter than the Coleman white gas stove which I also have.
  16. nineoaks2004
    2,601
    181
    Graceville, Florida
    I have one of the old green Coleman stoves, I converted it to LP, prior to that I soldered a schrader valve in the tank so I could pump air in with a bicycle pump while cooking. .
  17. rich2
    rich2 Active Member
    109
    27
    May 3, 2007
    Northampton, PA
    I have a few Coleman white gas stoves which I love, however bought a adaptor which allows be to use small propane bottles, now I have the best of both worlds.
  18. kitphantom
    10,293
    181
    Can you explain why it's now the "best"? I don't understand converting a good white gas stove to use 1# bottles. We actually like cooking on white gas, and it's easy to refill the tank, handy too, since the backpacking stove is also white gas. The 1# propane bottles are more uneven as they empty, as I found out with the Little Rec Campfire. (Once I had space in the TV to tote it, we bought another 20# LP tank.) Friends also ended up buying a 5# LP tank due to inconsistency with the 1# bottles on their cook stoves.
  19. rich2
    rich2 Active Member
    109
    27
    May 3, 2007
    Northampton, PA
    Well, the stove is actually not altered in any way, the is an adaptor which screws onto the propane bottle, and takes the place of the generator and white gas tank. By best of both worlds, I mean that it gives me the option to use white gas or propane. Sometimes I find it easier just to use a small propane bottle or attach the stove to a 20lb bottle, which then also runs my Coleman Propane lanterns. I find the propane burns hotter than the white gas. However with all being said, there are times I use white gas also, usually in the fall and the winter when it gets colder since the propane does not work as well in the colder temps.
  20. kitphantom
    10,293
    181
    Interesting, most of the propane camp stoves we've observed over the years have seemed wimpier than the white gas. We're very used to white gas. I literally don't remember seeing a Coleman camp stove in use for the first time, since my parents used one at our cabin and on the road. We can adjust it well - even the backpacking stove. That has the reputation for being a blowtorch, but DH manages to simmer quite nicely on it (secret: don't over-pump). It's easier to refill the fuel bottle with the bulk fuel, and it works better at altitude. We camp at 8,000' or so, DH sometimes is higher than that while backpacking.
    Glad there are so many options.
