Can I Remove Step?
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by KampFish, Sep 12, 2018.
  1. KampFish
    KampFish New Member
    Sep 12, 2018
    Can I remove the step next to the bed inside by pop up? Is it structural? I think it would give more floor space. Thanks! step - Copy.jpg
  2. Matt Benoit
    Matt Benoit Active Member
    316
    172
    Jul 30, 2017
    Warren, MI
    I had electrical running in the rear step of my pup. The front step collapsed under my weight last year. . Fortunately nothing was in there lol. Probably need to peak inside and see .
  3. gladecreekwy
    348
    332
    Sep 25, 2016
    I have the same step. Always thought about putting a hinge on it and making it storage for fishing rods. Don’t know what’s in there.
  4. mpking
    mpking Well-Known Member
    1,076
    185
    Jun 17, 2014
    Raynham, MA
    Mine has water lines in it for the Sholiet
  5. BikeNFish
    BikeNFish Well-Known Member
    1,889
    1,058
    Apr 24, 2017
    Maplewood, MN
    Just guessing, but I would think that it serves several purposes. It may hide wiring and it may stabilize the area between the sink and the storage area it connects to.
    kitphantom likes this.
  6. Raycfe
    13,942
    939
    On a Jayco the lift cables are inside. On our old Jayco we even made a bigger to help get into the bunks and stored our electrical cables, adapters, etc in it.
    So if yoy want to remove it ...look inside ...there may be something important inside or it just squares off the front panel angles.
  7. Raycfe
    13,942
    939
    Oh by the way
    Greetings from the Connecticut shoreline.
    KampFish likes this.
  8. Orchid
    Orchid Sharp Shootin' Grandma
    We recently built one of these into our camper. [LOL] Just shows how everyone has different wants/needs. We hinged the top of ours for a shoe bin. Got the idea from someone on this forum. We needed it as a step, too, now I don't have to have a step stool there.
  9. J Starsky
    J Starsky Well-Known Member
    542
    315
    Aug 3, 2017
    East Central MN
    Pilot hole. Have a look-see. Seal up if scary in there!
  10. bols2Dawall
    bols2Dawall S.W. Ontario
    1,366
    100
    May 19, 2010
    Lasalle Ontario
    Ballroom dancing ?
  11. Dingit
    Dingit Active Member
    525
    179
    Mar 8, 2017
    I like steps. But that one is right where you'd have only one leg on it when using the sink. I'd definitely take it out and rebuild it to a smaller size if it actually needs to cover anything. Whatever is in there, I bet it doesn't need to be that big!
  12. Orchid
    I noticed that, too. Would not want it in front of my sink.
  13. jnc
    Don't the crank cables run under that?
  14. joet
    3,650
    551
    Welcome from the West Virginia mountains,,, Don't know what's in the step, but welcome anyway
  15. nineoaks2004
    5,799
    2,063
    Graceville, Florida
    Welcome from N/W Fl, congrats on the NTU PUP. I would take a good look before ripping it out
    it might be important. Good Luck and Happy Camping
  16. BillyMc
    BillyMc Active Member
    433
    132
    Mar 25, 2018
    The wall behind it comes in at an angle. Removing it will give you surprisingly little if any additional floor space and make getting in and out of the bunk an bit harder. I am actually planning to add one for the rear bunk in our PUP, but I'm going to hinge the top for long item storage. Does it support the galley when folded?
