Can't crawl under camper
Discussion in 'Lift Systems' started by loveit, Nov 1, 2017.
  1. J Starsky
    J Starsky Active Member
    147
    76
    Aug 3, 2017
    Those pictures were worth a thousand words. - SOLD!!!!
  2. loveit
    loveit Member
    70
    May 12, 2011
    My wiffletree is at the back of the trailer. Even if I let the coupler jack all the way down the back is still too low.
  3. loveit
    loveit Member
    70
    May 12, 2011
    How did you get yours out, some sort of tool?
  4. tzmartin
    tzmartin Active Member
    573
    93
    Sep 9, 2015
    Pried it with a screw driver i think. Don't let it fall on you! The harder part is getting it back in. I wedged back in by levering it awkwardly with a thinner screwdriver. It's weird. Don't give up!
  5. Halford
    Halford Well-Known Member
    2,807
    194
    Sep 28, 2011
    Santa Clarita, California
    I would worry if I use ramp designed for auto/trucks. I just lower the tongue ALL the way down and did not have any trouble lubing the whiffletree. Of course the wheels are chocked. I do that in my garage.
    As for lubing the bearings, you gonna need stand under tubular frame, not under the "C" frame. the stand might slip off and camper falls on you. The stand might bust a hole under floor. then you got a new pee hole.
  6. Halford
    2,807
    194
    Sep 28, 2011
    Yes the cover is heavy. First I take off all screws but 4 (one each corner). If you have a stand or jack, it is a good time to put the stand or jack under the cover. take all 4 off. Then the stand or jack is holding the cover for you. That's what I do.
  7. kreeves
    kreeves She and her two dogs
    154
    26
    Dec 4, 2016
    West Virginia
    My whiffletree has 2 grease fittings, one on top in front, one on the bottom in the back. No need to remove the cover.
  8. f5moab
    1,438
    435
    May 7, 2013
    Somewhere in Idaho
    JPBar likes this.
  9. Halford
    2,807
    194
    Sep 28, 2011
    If you have a whiffletree, the cover must come off in order to replace old lube with new lube. Only Coleman popups have whiffletree.
    Haybale likes this.
