Carbon monoxide detector
Discussion in 'Heating / Cooling Systems' started by Bonecrusher, Nov 9, 2018.
  1. Bonecrusher
    Bonecrusher Member
    53
    May 5, 2018
    Hi ALL -
    I am planning on camping this coming week and will be using my furnace for the first time. I am thinking it may be a good idea to get a carbon monoxide alarm.
    Can I use an alarm from home depot used for the house? Or do I need to buy anything special??
    thank in advance !
  2. BikeNFish
    BikeNFish Well-Known Member
    2,205
    1,257
    Apr 24, 2017
    Maplewood, MN
    You can't go wrong getting a carbon monoxide alarm for peace of mind, but I wouldn't worry too much about your furnace producing CO unless your furnace is old and corroded. Most CO poisoning comes from leaky exhaust from a generator, stand alone gas heaters or from someone else's exhaust when camping in close quarters.
    HERE is a link on CO awareness that may be informational.
  3. Snow
    9,517
    678
    A regular battery powered detector for the home will work..
  4. Spridle
    Spridle Member
    713
    Jun 6, 2011
    I have the LP/CO detector in mine and the only problem is that it goes off in the middle of the night if the battery sags too much.
  5. Bonecrusher
    Bonecrusher Member
    53
    May 5, 2018
    Thanks all!
  6. nineoaks2004
    6,277
    2,345
    Graceville, Florida
    Get the detector and install it, Better to be safe than sorry..
  7. Bonecrusher
    Bonecrusher Member
    53
    May 5, 2018
    I installed it. Ran heat alll night. Worked great in the 28 degree night! Maintain about 60 degrees on the lowest setting of thermostat..
    Thanks all!
  8. Fless
    Fless Active Member
    899
    166
    Aug 14, 2012
    Colorful Colorado - the Centennial State
    No real need to install anything. I've been using these battery operated CO detectors by Kidde for years, and you can take them with you wherever. Available just about anywhere for less than $20.
  9. Toedtoes
    Toedtoes Well-Known Member
    1,097
    675
    May 28, 2018
  10. MyName
    MyName Active Member
    262
    56
    Jan 12, 2018
    Ca
    I installed a safe T Alert because I wanted the LP alarm also. Overkill? I don't know, but I feel safe.
