Check Galvanic Rod
Discussion in 'Camper Storage / Winterizing & De-Winterizing' started by MintHillBill, Dec 4, 2018.
  1. jmkay1
    4,334
    1,280
    I do not think so. There honestly isn't much difference but enough of one where it could leak if you don't get the correct size. My dad bought one without looking it up in his manual and although it fit it wouldn't screw on tight enough to not leak.
  2. Halford
    Halford Well-Known Member
    3,557
    544
    Sep 28, 2011
    Santa Clarita, California
    Yea, Snow, I just discovered this after lots of researching. 3/4" x 9.5" by using 1 1/16 socket. I ordered 2 from Amazon and should get it before I go camping this Friday. I do not really use the hot water much but I want a peace of mind.
  3. Tundrayetti
    Tundrayetti New Member
    Green Valley, CA
    Figured I’d revive this thread with a question I have about my anode rod.
    2001 Sea Pine. Bought last year and recently pulled the anode rod.
    Good news: Took some effort due to rust, but was able to remove it.
    Bad news: It MUST be the original. It is worn down so bad that the rod is about the diameter of a 12 ga wire. And even that seems brittle. Almost a black oily substance on it as well.
    I put it back in until I have more time to deal with it.
    My question: It doesn’t seem as though a new one would fit, due to all the build up. Does anyone have experience with how I should proceed?
  4. crackerJack
    crackerJack Well-Known Member
    1,102
    278
    Jan 6, 2014
    Scottsville, KY
    I use a wire brush to clean the threads.
    Tundrayetti and Sjm9911 like this.
