Coleman ABS Roof
Discussion in 'Roof/Floor Repair & Maintenance' started by benfrench, Oct 11, 2011.
Have you had any issues with your Coleman ABS Roof?
  1. Yes, sagging, I fixed it ..
    15.2%
  2. Yes, sagging, I got rid of it ..
    4.5%
  3. No, never had any issues ..
    32.7%
  4. Yes, cracking, I fixed it ..
    50.6%
  5. Yes, cracking, I got rid of it ..
    11.3%
  1. gigfy
    gigfy New Member
    Sep 25, 2017
    Thank you very much! And also for the nice instructions.
    https://2001colemanutahcp.blogspot.com/2016/08/prepping-for-new-roof.html
    MrsSquid likes this.
  2. MrsSquid
    MrsSquid Active Member
    298
    98
    Aug 31, 2016
    Virginia
    You're welcome. : ) I was talking with my husband at lunch about this. He stressed that you really need to spend the time in the preparation. It's a pain, but you'll like the results.
  3. Pjulm
    Pjulm New Member
    Mar 24, 2018
    I have a 2000 Coleman Utah pretty much got it for a steal. I am currently working on the flooring and 2 of the inner walls but the room is on my mind. The roof has alot of cracks I'm thinking of doing the pop up princess fix which is peeling off all the ABS and recoating the fiberglass with grizzly adheasive and abs pellets to make a new abs covering, I think it is sagging though. If i load some pictures can someone advise me? I really want to put my blood sweat and tears into it but only if it is going to be worth it
  4. jnc
    3,896
    1,139
    Oct 1, 2014
    South Central New Hampshire
    You should start a new tread in the Restoration forum
    http://www.popupportal.com/forums/camper-restoration-projects.160/
  5. HotelRoyale
    HotelRoyale Member
    89
    38
    Sep 23, 2016
    Sure, post some pics ... but if you got it for a song I'd say, yes, it's worth it to do the work ... if you're handy enough. The sag will be the hardest to deal with but if you've already got the roof down to the bones you're halfway there. I looked for your thread in the restoration section but didn't see it?
  6. NiteRider
    NiteRider New Member
    22
    May 3, 2018
    Ohio
    Have a 96 coleman fleetwood key west i recently acquired with roof sag/ desalination and cracking. I figured out how to fix the delamination and cracking but still mulling over the sag issue. Was thinking of running 2 pieces of angle iron across the top width wise and dropping some all thread down through the roof to a couple plates to draw the roof up (then seal it all like crazy) has anyone done anything similar?
  7. jnc
    3,896
    1,139
    Oct 1, 2014
    The side walls need to be pulled back in. This will put the bow back in the roof.
  8. NiteRider
    22
    May 3, 2018
    Ohio
    Ah, ok. What's the slope on that? An inch or so drop from center to edge?
  9. jnc
    3,896
    1,139
    Oct 1, 2014
    I will try to get you a measurement off of mine but dont know how similar they are.
  10. Jml96sv
    Jml96sv Member
    44
    Feb 19, 2017
    May I ask how you fixed the delamination? Do you have A/C?
  11. NiteRider
    22
    May 3, 2018
    Ohio
    I'm hoping to get around to doing that this weekend. Im going to use gorrilla glue to repair the delamination. I have started a new thread in the roof/floor repair section and I'll try and post some detailed pics of the full roof repair.
    Edit: yes I do have an a/c I think that's what made the roof sag so much to begin with
  12. Sjm9911
    2,344
    889
    Question, I just got , and have not towed home a 2000 Colman Westlake. It has crazing but no delamination. Is it best to remove and grizzly grip or is this another repair? Is it possible to inject gorilla glue under the top and then put on the grizzly grip? Just wondering?
  13. jnc
    3,896
    1,139
    Oct 1, 2014
    I have been needing to do some kind of ABS repair for 4 years now. So I have done a lot of reading on this subject. Many folks make a 50/50 mixture of ABS & Methyl Ethyl Ketone (M.E.K). This turns into a Slurry to fill the cracks. Sometimes they will go over these repairs with the GG. Others remove the whole roof & fill any voids in the foam with Bondo than cover with GG. This is the method I would do if I had the cash. As for injecting glue underneath the ABS it has also been done. Good Luck and Dont forget we will need to see some photos of your project.
  14. Sjm9911
    2,344
    889
    I'll start a thread when I get going on it. So pthers can learn from my mistakes, lol . Thanks for the info.
    jnc likes this.
  15. PUPLizCA
    PUPLizCA New Member
    22
    Jun 22, 2018
    034BE6B4-1BDF-4ACB-8023-86D6E2C01DF6.jpeg 028CEDF6-5A87-47E0-B25E-97897D719FC0.jpeg Is this a sign of Delaminating? Also I am thinking these bars were installed for support.
  16. Sjm9911
    2,344
    889
    It does look that way but there might be more going on then we can see, bars were probubly put in to fix a sag issue. I don't see cracks and the roof looks repainted. So this might be the worse that it gets. Hard to tell
  17. PUPLizCA
    PUPLizCA New Member
    22
    Jun 22, 2018
    The
    The roof has been repaired with MEK and repainted. But I won’t be able to attach an awning or bike rack which are two things I wanted. I have a ez up and my ex is making me a bumper so I can use a bike rack sowe solved the problem. But I would like to make the roof look better. They didn’t even remove the gasket when they repaired it so there is paint all over it.
  18. mstrbill
    mstrbill Active Member
    659
    135
    Mar 17, 2013
    Austin , Texas
    I can't think of anything else that would look like that.
    Don't think so, those are most likely to fit racks, possibly for bikes. If it was to combat sag, the the tubing would run front to back.
    Painted with what? If you don't mind drilling holes and sealing them, you can use a metal awing rail.
  19. Sjm9911
    2,344
    889
    I think you may be right, it dosent look as if the bars reach far enough across, the factory supports they added run that way, mine has one on the inside. Some bought a second one, was thinking that it was a attempt to combat sag that was maybe pushing the sides out. Lime a collar tie. Only person that really knows is the person that put them in.
  20. PUPLizCA
    PUPLizCA New Member
    22
    Jun 22, 2018
    It not a smooth feeling finish almost like flat wall paint. They didn’t take off the gasket so it’s chipping off. I’m afraid to drill into it. Then if I do it will start to chip away. If and when I redo the roof I want to remove everything so it’s completely covered. Thanks!
