Coleman Crank-Up Ratchet Failing
Discussion in 'Miscellaneous Repairs & Maintenance' started by Mr_Custom, Jun 18, 2007.
  1. Mr_Custom
    Mr_Custom Member
    847
    Jul 14, 2006
    Antigonish, Nova Scotia
    On a Coleman 2003 Sun Valley I had some problems getting the crank up ratchets to engage the first time out this year. I hit it with some silicone spray as best I could around the opening to the crank and they caught and worked fine both up and down.
    Next time out once again, they did not engage and I tried the lube trick again with no luck. Eventually with the help of some hammer tapping and rattling I got them to click in.
    Looks like the crank assembly may need some more TLC but before I start taking apart the camper to expose the workings I thought I would check to see if anyone had experience with a similar problem?
    Thanks in advance!
    Mr_Custom
    Antigonish, NS
    2005 Chev Trail Blazer
    97 F-150
    03 Coleman Sun Valley
  2. backwoodzbum
    backwoodzbum New Member
    477
    Jun 15, 2007
    I would go to an auto parts store and by some of the electrical contact type cleaners(CNC brands are great)). They are very good for greasy dirty cleanups and they evaporate to a clean metal finsh. Then reapply the silicon spray. I am almost sure it is just dirt grime buildup causing your problem.
    ________________________
    <img src=../Images/icons/icon_smile_pu.gif border=0 align=middle>...92 Jayco 806
    <img src=../Images/icons/icon_smile_suv.gif border=0 align=middle>...96 GMC Jimmy
    Steve
    Gina
    Tabitha
    Emily
  3. achurch2k
    achurch2k New Member
    302
    Feb 21, 2006
    Glendale, Arizona
    I would agree, it is probably an interference problem of some sort. I suspect that the 'heavy' grease and dirt/dust mixture from driving down dirt roads (if you do) could likely be the culprit. Although, after your experience I am going to closely examine my 96.
    Alan
    1996 Coleman Cheyenne
    1999 VW Eurovan
    Janay+Hannah+Aidan
  4. mi_hiker
    mi_hiker New Member
    Jun 18, 2007
    I had a problem with the crank & lift on my '95 Coleman Cedar. The clutch would engage for about six inches of lift then slip completely.
    I was ready to tear into it and make repairs.
    I did my research and examined my owners manual, the lifts system manual and finally my warranty.
    To my surprise, my warranty stated that the lift system has a lifetime warranty.
    Well, I towed it down to the local dealer, who is still a Fleetwood dealer and they fixed it for free!
    If I remember correctly, they replaced the gear box and the drive shaft/socket, all at no cost to me. (The drive shaft/socket sleeve where the crank slip into had split about four inches.)
    Now I do not know how different the lift mechanism is between a '95 and an '03, nor if the warranty has changed, but it's worth looking at.
    Good Luck
  5. Fairview 2001
    Fairview 2001 New Member
    321
    Dec 27, 2002
    Did it crank up quietly or not crank up at all? This is common for Coleman ratchets and all you are supposed to do is crank all the way up then over crank it just a little and the ratchet resets itself.
    The solution, as should be described in your owner's manual, is to crank the roof to full extension and then overcrank it slightly. Assuming nothing else is amiss, this will re-engage the lift system ratchet and operation should then be normal. The key to having this not happen again is to not overcrank it when you lower the roof ... just lower it enough so you feel the cables go slack, no further, even though there still may be a couple of turns potentially left.
    <font color=red><center><img src=../Images/icons/icon_smile_ranger.gif border=0 align=middle> Ron & Barbara <img src=../Images/icons/icon_smile_bike.gif border=0 align=middle>
    '01 Coleman Fairview W/GlideOut <img src=../Images/icons/icon_smile_pu.gif border=0 align=middle>
    2004 GMC Sierra 1500 W/Sway Control
    3 Fantastic Boys</font id=red> <img src=../Images/icons/icon_smile_camping.gif border=0 align=middle><img src=../Images/icons/icon_smile_kayak.gif border=0 align=middle>
    Our General Store
    <font size=4>Click Here To See Our Photo Site</font id=size4></center>
    Patrick Charb likes this.
  6. Patrick Charb
    Patrick Charb New Member
    Jul 11, 2018
    thank you so much
    great
    it's work !!!!
  7. crackerJack
    crackerJack Well-Known Member
    1,054
    235
    Jan 6, 2014
    Scottsville, KY
    My chain had developed slack over time and would slip occasionally. Removing a link solved it.
