Coleman Lantern - my winter project this year
Discussion in 'Lighting, Interior and Exterior' started by thethird152, Dec 1, 2017.
  1. Bowman3d
    Bowman3d Active Member
    740
    230
    Apr 13, 2015
    LaLa land (SoCal)
    If you take the generator off the valve and open the valve and it gets fuel then your gen is probably clogged. Very carefully pull the cleaning rod out of the gen there is a spring and a cardboard tube in the gen. Pull them out and clean the spring. Carefully put it back together. Be super careful not to bend the wire on the rod. Once back together soak it with carb cleaner. Put gen back on the valve and recheck to see if you get fuel through the gen.
    Edit: the generator is the brass rod sticking up off the valve the air supply tube is the steel ,tube that’s behind it on the piece you took off. The whole part is the burner assembly.
  2. Bowman3d
    740
    230
    Apr 13, 2015
    LaLa land (SoCal)
    Just reread your prior post. With the burner assembly off you will not get a hiss just fuel squirting from the gen.if you get fuel then I say check the burner assembly, air tube and burner tubes( the tubes the mantles tie onto)to make sure they are clear. There are screens on the mantle caps that get clogged and insects like to build nests in the tubes. If you have an air compressor that will help greatly in clearing them. Also a bore brush from a gun cleaning kit.
  3. Bowman3d
    740
    230
    Apr 13, 2015
    LaLa land (SoCal)
    Only advice I can give you is build shelves. These things breed like rats. And don’t think about single burner stoves .
    A few more lanterns and 5 stoves (plus 1 I’m picking up tomorrow, my first European stove) have been added since this was taken.
    Katskamper likes this.
  4. xxxapache
    2,623
    666
    Yeah, I have a pile about like that. I have tried to quit carrying them home.
    Bowman3d likes this.
  5. Katskamper
    Katskamper Active Member
    741
    189
    Nov 21, 2015
    Fort Worth, TX
    im slightly mechanical. parts that could come apart easily have been taken apart . its CLEAN.
    Do i disassemble the main gas tank from stem/generator?
    -screen refresh showed the other posts. will try tonight.
    there are no moving parts (other than on/off knob)!
    XxxApache, what would you do next?
    but, this is why it was in garage sale....
  6. Katskamper
    741
    189
    Nov 21, 2015
    Fort Worth, TX
    SWEET.
    dang, can i come hang w you?
  7. Katskamper
    741
    189
    Nov 21, 2015
    Fort Worth, TX
    my 2 car garage is packed w camp gear. open cargo trailer packed w totes, tents, cots, heaters, icechests for camping in large entourage.
    wall shelves hold empty water jugs & light gear.
    other side is popup.
    6 inches from dryer in garage.
  8. xxxapache
    2,623
    666
    Is the tank building pressure?...if not, there is check valve in the tank behind the pump that you can clean or replace. If it is building pressure, I would replace the generator.
  9. Katskamper
    741
    189
    Nov 21, 2015
    Fort Worth, TX
    fuel squirts from generator tip, fine syringe stream. thats what i want right?
    i will clean the insides of this part again. dont have gun cleaner.
    also saw the original slant glass lantern & yellow case like i just got on fb mktplc for $50. quite a few for sale!
  10. xxxapache
    2,623
    666
    It should be hissing.
  11. Katskamper
    741
    189
    Nov 21, 2015
    Fort Worth, TX
    dfw area sales. note the yellow case & lantern. thats the original?
    i just got this case & funnel with lantern (that doesnt work)
    will visit thhrift stores tjis weekend.
  12. Bowman3d
    740
    230
    Apr 13, 2015
    LaLa land (SoCal)
    Depends you can buys different cases for different lanterns. FYI the case by itself is worth $30 easy.
  13. xxxapache
    2,623
    666
    Yep, that case is easily a 30 buck item. I have a couple. The lantern is a 275. I have a few of them.
    While there are a few of us here nuts about Coleman liquid fuel stuff, it's really not in high demand. I find it at flea markets all the time and have started passing up most of it, because after I bring it home, I can't unload it. I have advertised some nice pieces on CL and similar with not much interest.
  14. Bowman3d
    740
    230
    Apr 13, 2015
    LaLa land (SoCal)
    I bought a case for $30 came with a free 220k with an Amber globe.
  15. xxxapache
    2,623
    666
    The last case like that I bought had a 275 with cracked glass....I paid 15 bucks.
  16. Katskamper
    741
    189
    Nov 21, 2015
    Fort Worth, TX
    i want one of the old style to use, thats not the disposable green can type.
    i love my hurricane lanterns, but even those are prohibited during Texas burn bans.
    consolidating packing- is the coleman gas suitable for hurricane lanterns?
    the case is a keeper! i gave up on glass, went with screens. but now that i have a case...
  17. Katskamper
    741
    189
    Nov 21, 2015
    Fort Worth, TX
    would you ID this stack?
  18. Bowman3d
    740
    230
    Apr 13, 2015
    LaLa land (SoCal)
    Let's see the stoves from the top down. 425c, 413g,413g,426b. Missing stoves 426b, m1950 Rogers,m1950 fiesta, Coleman 530, Coleman 502, and Optimus 80. Lanterns the 2 hanging by stoves on left Coleman 1958 Mil-spec, on right 1963 thermos mil-spec. On table from left to right 200a,290 duel fuel,behind is a Sears double mantle 220 size,in front of that is a 228f big hat,behind that 220e,in front 288 with sportsman globe behind that a 220K and a 200a on the end. Missing lanterns 228D, 220E,220J,and a 5120 propane
  19. Katskamper
    741
    189
    Nov 21, 2015
    Fort Worth, TX
    whoo hoo!
    Nearby resale shop had a Coleman CL2 (model 288) for $15.
    It came home with me!
    Other than cobwebs, in great shape for a 1985 gas lantern.
    Determined to get one that works!
    edit: new mantles, fresh gas. pumped it up & it lit on first try! WHOO HOO!
    kcsa75 likes this.
  20. xxxapache
    2,623
    666
    The 288 is a handy little lantern because it and it's case are compact.
