Coleman outside stove
Discussion in 'Propane - Got Gas' started by scottveazie, Jul 24, 2017.
  1. Douggro
    Douggro Member
    125
    18
    Jul 26, 2017
    Seattle, WA
    You've got a different stove than I do? You had me not trusting my recollection of a replaceable hose. Do you not have that fitting/connector between the main supply and the burner? You can see mine's a Wedgewood model in the attached pic. Had it out test-burning after re-doing the front end of the LP distribution to fix a leaking service selector unit.
  2. scottveazie
    scottveazie Member
    52
    Aug 9, 2010
    IMG_1038.JPG IMG_1037.JPG Same stove, worse connection I think on mine..
  3. Fless
    Fless Active Member
    @scottveazie, what's the rest of your outboard crimp fitting look like, to the right of what is within the red square on the short pigtail?
    See the next pic; is your threaded male part (like in the green oval) missing?
    Here's the hose that is on my stove, and it's about 34" end to end:
    Those are standard connectors, and if your pigtail is missing the threaded part of the crimped connector, you'll probably have to have another one crimped on if there's enough hose. Then you can get a standard hose to extend it to your frame connection (POL).
    _
  4. scottveazie
    scottveazie Member
    52
    Aug 9, 2010
    Yup, mine is missing. I think I'll see if I can get a new hose crimped on. I do have an adapter from 3/8 to the Coleman style connector lying around.
  5. scottveazie
    scottveazie Member
    52
    Aug 9, 2010
    IMG_1095.JPG Finally got a custom hose crimped on and a few Coleman trailers ago I had this funky left threaded 3/8 to Coleman adapter. Works like a charm!
