Coleman step door lock replacement
Discussion in 'Miscellaneous Repairs & Maintenance' started by RogerCamper, Feb 22, 2011.
  1. Hey im Jay
    Hey im Jay Member
    56
    17
    Feb 5, 2018
    When I just bought mine recently the key was already broken inside I can't figure for the life of me how to get it out I do not have a pair of tweezers that small you get in there with this be something a locksmith could do without taking the door apart
  2. Fless
    Fless Active Member
    915
    178
    Aug 14, 2012
    Colorado
    You could try a sharp pick or a couple of strong pins to work out the broken key. I did one yesterday in a file cabinet at work. If that doesn't work, check with a locksmith; bet they do this all the time.
    _
  3. Hey im Jay
    Hey im Jay Member
    56
    17
    Feb 5, 2018
    Thank you
  4. DJS12354
    DJS12354 Well-Known Member
    1,543
    474
    Sep 21, 2017
    Try opening the door (if you can) and giving a sharp rap just behind the lock while holding the door so it can't move. Another option is to try a strong magnet, such as a mechanic's pickup tool.
  5. ezakoske
    ezakoske Active Member
    498
    57
    Nov 30, 2014
    Escondido, CA
    For anyone needing to repair/replace their door lock/latches, the Popup Princess has a pretty good tutorial on how to go about it. I followed it and was able to get my latch on the left side working again (turns out it had just fallen and needed to be placed back in position.
    http://www.thepopupprincess.com/pop-up-camper-maintenance/replace-the-lock-on-your-pop-up-camper/
    Door lock: https://colemanpopupparts.com/products/access-door-lock
    Replacement keys (if you can get the old one out...): https://colemanpopupparts.com/search?q=key
    Not that hard a job - even if you have to replace the entire lock assembly.
    good luck!
    Erik
  6. durhamcamper
    durhamcamper Active Member
    709
    155
    Apr 21, 2010
    Pickering, Ontario
    How about a drop of super glue on a blade of a screwdriver. Carefully put the blade together and let it set for a minute. Pull the key out, snap off the key.
  7. up_north
    up_north New Member
    Jul 29, 2018
  8. myride
    myride Well-Known Member
    778
    349
    May 14, 2015
    Edmonton, AB
    Like mentioned.....2 sharp objects and grasp/pinch what looks to me as a bit of key protruding.....work it slowly but should come out.....short of that a locksmith should be able to do this.
  9. Fuzzy Bear
    Fuzzy Bear Active Member
    492
    93
    Mar 3, 2004
    Norwalk CT
    A locksmith can definitely get the broken piece out (I am one). One thing I've used in the past is a "spiral scroll saw blade" that you gently slide in next to the key. Then twist it carefully to bind against the key and gently pull until you can grasp it with a pair of tweezers or needle nose pliers.
    jnc and myride like this.
