converter 12V output rectification recommendations
Discussion in 'Wiring' started by EdZilla, Nov 10, 2017.
  1. EdZilla
    EdZilla Member
    75
    Sep 19, 2017
    Denver
    I have a MagnaTek 6400A Model 6409 Converter
    http://www.popupportal.com/media/img_6162.9520/
    It works fine, but I think that when it's on shore power, although I can run the LED lights, the 12V output is not clean 12V DC. I don't have an oscilloscope, but when I put a meter on it, the reading jumps around a little, and so I suspect that it's lumpy DC.
    I'd like to be able to run certain electronics equipment off the 12V, but I need it to be clean regulated 12V. For example, I plugged in an inverter (DC to AC) to the 12V cigarette lighter style adapter and it errored out and would not work.
    Hopefully my explanation is sufficient to describe what I'm trying to do and someone can recommend a simple solution.
  2. theseus
    theseus Centerville, OH
    2,573
    274
    Feb 6, 2007
    Centerville, OH
    Is this the original converter? If so I would replace it with a newer converter. The newer converters have better quality 12v power, or so they say.
  3. xvz12
    xvz12 Well-Known Member
    657
    315
    Apr 6, 2017
    New Plymouth, ID
  4. theseus
    2,573
    274
    Feb 6, 2007
    Centerville, OH
    After looking at your picture, it does appear to be an original unit. I would definitely replace it with a newer unit. Converters eventually go bad. A newer unit would, in my opinion, provide cleaner power.
  5. EdZilla
    EdZilla Member
    75
    Sep 19, 2017
    Denver
    That's not exactly what I'm looking for, but is an inexpensive option and maybe the best solution since I'm really just trying to get clean DC when running on shore power.
  6. EdZilla
    EdZilla Member
    75
    Sep 19, 2017
    Denver
    It is an original unit, so and the camper is a 1994 model so it's at least that old. It works, so unless I can find a really inexpensive and superior replacement, I'll look for another solution.
  7. 1380ken
    1380ken Well-Known Member
    1,750
    325
    Nov 7, 2013
    Mass
    I don't understand. When you are on shore power only the lights are 12v from the converter. Why would you need a clean 12V. Why would you need to go from 12V to AC when you have AC shore power? If you want a clean 12v for something else just plug in a 12V power supply into your AC receptacle.
  8. Aladin Sane
    962
    47
    Jul 3, 2008
    Iowa
    Ok, maybe I'm missing something, but if you have shore power, why not just plug a regulated power supply into one of your outlets and plug your 12 volt device into that? Why bring the converter into the mix?
    Doh!!! Beaten to the punch I see.
  9. Customer
    Customer Well-Known Member
    2,429
    231
    Jun 5, 2014
    Same question as others, why use an inverter if plugged into shore power?
  10. roybraddy
    roybraddy Well-Known Member
    1,774
    495
    Mar 23, 2016
    King George, Virginia
    Some of the older converters where so weak in DC REGULATION they wanted the Installed BATTERY to help provide additional DC regulation. One version even had a DC CONTACTOR involved that if a Battery was not connected the converter would not have any DC OUTPUT. I believe those where the MagnaTek models.
    The original concept may have been everything would run from a 12VDC Battery and when things evolved into using 120VAC for modern day appliances etc then the early converter was only a DC Charger to keep the battery charged. Todays 12VDC and 120VAC requirements have come along way since the earlier RV Trailers.
    Here is a typical 30A Power Distribution plan for the modern day trailers...
    The main thing this drawing shows to me is the two distribution panels are the center of how the trailers works. You will notice that the 12VDC Distribution Panel where all of the 12VDC Requirements are wired to and are fused and have two 12VDC sources connected. One source being the 12VDC battery and the other other being the DC Converter that produces 12VDC that is operated by plugging the shore power cable into a 120VAC Source which can be a Camp Ground Pedestal or a 120VAC Generator set. Both of these 12VDC sources feed the same terminal on the 12VDC Distribution Panel.
    Having the two 12VDC sources allows the trailer to be used to operate modern day appliances as well as the BARE necessities when camping off-grid somewhere...
    Being an avid tent camper from the 60s my camping modes is for the most part camping OFF-GRID somewhere without Shore Power which requires me to have a beefed up battery setup and ways to keep my charged for long periods of camping away from standard shore power areas. Oc course you see I have a 13500 Air Conditioner on top of my OFF-ROAD trailer but it very seldom gets use except when we are camping at shore power camp grounds. Would take many many batteries to make it operate when OFF-GRID.
    Roy Ken
  11. rabird
    6,347
    167
    TX
    I believe that is not correct. The conv/off/batt ISOLATES the transformer from the battery so there is no way to connect the 'converter' to the battery.
    A battery may be an option for clean 12v.
  12. NMroamer
    NMroamer Active Member
    377
    150
    Apr 21, 2016
    Albuquerque NM
    Wow a lot of suggestions to help but rabird nailed it.
    A battery is the best clean 12 volt power you can get for the money.
  13. 1380ken
    1,750
    325
    Nov 7, 2013
    Mass
    Until it is discharged
  14. EdZilla
    EdZilla Member
    75
    Sep 19, 2017
    Denver
    It’s a fair question.
    When on shore power the lights are generally all that is 12V, and they aren’t sensitive to variations in the 12v output, however some electronics are. For example, an (expensive) ham radio that runs off of 12volts probably needs to be powered by a clean regulated 12V source. My converter 12v output is definitely not clean 12v.
    The other question is also fair, and I️ should have explained. I️ wasn’t intending to use the inverter, it was just to test how some 12v electronic systems would respond to my converters 12v output when on shore power. Plugging in the inverter to my 12v source when on shore power and seeing that it did not work was verification that some 12V electronics would not work because there is something anomalous with the 12V from my converter when on shore power.
    The third question you asked is also fair. I️ could plug a 12v supply into the receptacle and get clean 12V (something Wynn first suggested) but what I’m doing is wiring a 12v accessory panel directly from the converter 12v output. The source 12v to the panel should be clean whether it’s battery or from the converter.
    In retrospect, I️ probably should have explained my motivation from the start.
    Make sense?
  15. EdZilla
    EdZilla Member
    75
    Sep 19, 2017
    Denver
    Yes, until it’s discharged. Currently I’ve wired my 12V accessory panel directly to my battery so that it’s clean 12v, but that means that I’m draining the battery even when on shore power. This is the reason I’m trying to clean up the converter 12v output so I️ can use it for even my most sensitive electronics.
    I️ have plenty of options and I️ welcome the discussion we’ve had here.
    I’ll probably go the additional 12V power supply idea that Wynn (xvz12 ) suggested.
  16. Fbird
    Fbird Active Member
    262
    107
    Sep 10, 2017
    Ferndale MI
  17. EdZilla
    EdZilla Member
    75
    Sep 19, 2017
    Denver
    Agreed.
    The previous owner did some hacking on it and so I’ve been in there a fair amount to clean things up. I’m making sure all the connections are solid, and that I️ have proper wiring harnesses, strain relief and bus bars where it makes sense.
  18. EdZilla
    EdZilla Member
    75
    Sep 19, 2017
    Denver
  19. theseus
    2,573
    274
    Feb 6, 2007
    Centerville, OH
    Yes it does. It's more expensive though then a new power center, which would have a new converter and charge the battery.
  20. NMroamer
    377
    150
    Apr 21, 2016
    Albuquerque NM
    As a ham radio buff you might be able to add a filter in line on the 12 volt source.
