Converting Dual Tanks to HP and LP
Discussion in 'Propane - Got Gas' started by cahillprc2, May 11, 2017.
  1. cahillprc2
    cahillprc2 Member
    51
    Sep 2, 2011
    Catonsville, Md
    I currently have dual tanks on own Somerset Off-Road pup that both go thru a low pressure regulator with a manual switch to change tanks. We rarely use the pup furnace. How difficult would it be to change one of the tanks to use with a HP stove on the side of the camper? Also can I use a quick connect at the end of HP line to for hooking up stove? Last question, should I use a threaded plug to close the open side of the regulator or is the manual switch pretty much "fail safe"? Any advice or suggestions greatly appreciated.
  2. tombiasi
    If you HP stove has it's own regulator then you only need to feed it directly from the tank.
    Quick connects are for low pressure.
    Wouldn't hurt to close an open fitting.
  3. Sneezer
    Sneezer Active Member
    329
    33
    Just get a tee and an extension hose to hook up to your stove outside. That would be the cheapest option I think.
  4. SteveP
    SteveP Member
    432
    I use the
    Marshall Extend-a-Flow Adapter
    between one tank and the auto change over regulator to run my Camp Chef hi pressure Mountain stove. If you put it on the primary tank you have to move it if the primary runs out. On the secondary you are pulling from both tanks.
  5. crackerJack
    crackerJack Member
    665
    22
    Jan 6, 2014
    Scottsville, KY
    LP uses quick connect.
    HP uses a threaded connection, ex coleman propane canisters.
  6. mstrbill
    mstrbill Member
    132
    17
    Mar 17, 2013
    Austin , Texas
    That doesn't sound right, the whole purpose of a changeover valve is to isolate the tanks to keep from emptying both tanks
    I am not familiar with the Somerset line, are you talking about a built-in stove or a standalone stove. If stand alone, the Marshall adapter suggested by Steve and a long hose would allow you leave the tank connected to the trailer and have the stove on the side of the PUP.
  7. Boatnman
    Boatnman Active Member
    380
    60
    Jan 19, 2017
    western Colorado
    So you are disconnecting one of your tanks from the manual switch-over regulator. It would be a good idea to plug the opening. That leaves you one tank serving the PUP through the regulator and a spare tank just sitting there. To connect a high pressure stove that DOES NOT have a built-in a regulator to that spare tank, you will need something like this (with the stove end fitting to match your stove):
    https://www.amazon.com/Pressure-Propane-Adjustable-Regulator-QCC-1/dp/B00NO1O6ZC
    To connect a high pressure stove, such as a standard Coleman stove that uses 1# bottles, to that spare tank, you will need something like this:
    https://www.etrailer.com/Propane/Camco/CAM59825.html
    Hose length optional, no quick disconnects.
  8. mstrbill
    mstrbill Member
    132
    17
    Mar 17, 2013
    Austin , Texas
  9. cahillprc2
    cahillprc2 Member
    51
    Sep 2, 2011
    Catonsville, Md
    Thanks everyone. This HP/LP stuff is a little confusing to us newbs. So essentially, the pressure in the 1# tanks is the same as the 20# tanks. Is that correct? And everything in the camper runs off of low pressure coming from the regulators on the big tanks ? I wouldn't be considering all this but would like to be as frugal and "green" as possible by not using the 1# bottles.
  10. Boatnman
    380
    60
    Jan 19, 2017
    western Colorado
    Yes, a 20# cylinder generally has the same pressure as a 1# bottle and everything inside the PUP is low pressure.
    Stoves, lanterns, heaters, grills, etc. that use a 1# bottle have built-in regulators. Some stoves and grills are high pressure but don't have a built-in regulator so the propane has to go through a high pressure regulator before going into the device. High pressure regulators are adjustable and are red like this: https://www.amazon.com/Bayou-Classic-Pressure-Regulator-Control/dp/B000C1Z1F6
    The propane tree and tank tee mstrbill mentioned are good options if you want to connect more than one device to the tank at the same time. The tree is a really good option if you use a lantern that normally mounts on top of a 1# bottle.
    As an option to carrying several 1# bottles or lugging a 20# cylinder around camp or running long hoses, smaller propane cylinders are available such as a 5# or 11# that are refillable.
  11. rabird
    5,849
    21
    TX
