Coupler Locks...
Discussion in 'A-Frame PopUps' started by Rik Peery, Jun 15, 2018.
  1. Rik Peery
    Rik Peery Active Member
    398
    236
    Jun 15, 2018
    Virginia
    Wondering what type of lock if any y'all use as a deterrent for your ball hitch; my Ranger 10 has the 2" a frame coupler w/ a raise & "pull back" system on the ball mount; thanks ahead of time...
  2. Raycfe
    14,007
    951
    Padlock or hitch pin with chain.
    xxxapache and Rik Peery like this.
  3. Snow
    9,405
    640
    padlock while parked.
  4. jnc
    3,896
    1,139
    Oct 1, 2014
    South Central New Hampshire
    Padlock is all I use. If they want it bad enuff no lock will stop them.
  5. soft 17
    soft 17 Active Member
    241
    103
    Mar 14, 2017
    San Luis Obispo
    Just a Master lock pin made for trailers. $5 from walmart.
    Rik Peery likes this.
  6. Rik Peery
    398
    236
    Jun 15, 2018
    Virginia
    Thanks for the responses, already had a wheel lock & keep it under the car port here at home, considering keeping it near the lake at a pal's enclosed locked storage lot later this year for a few months next to his restaurant until December...
  7. jnc
    3,896
    1,139
    Oct 1, 2014
    If you are really worried about theft you can take a tire or two off & or put the Stabs down. The harder you make it the less chance of anything happening.
  8. Rik Peery
    398
    236
    Jun 15, 2018
    Virginia
    Yepper, not that worried, as he has cams & never had a prob, but good idea under certain circumstances; recently read where an Aliner had been taken in front of someone's home, crazy arse wolrd we live in...
  9. Toedtoes
    Toedtoes Well-Known Member
    1,010
    623
    May 28, 2018
    I got a hitch and coupler lock set from O'Reilly's. Use the same key. Figured since my FnR is parked right out front I wanted something to make it less easy.
  10. jeicher
    jeicher Member
    68
    34
    Sep 17, 2011
    Coupler locks will lock the coupler, but if someone wants to steal your camper they just hook up the safety chains to the back of their truck and away they go. a good chain through the wheel and over the axle with a pad lock is a better deterrent.
    Grousetales and Rik Peery like this.
  11. xxxapache
    2,581
    633
    If someone wants to steal your camper, they will come armed with bolt cutters for either chains or padlocks.
    soft 17 and Rik Peery like this.
  12. Toedtoes
    1,010
    623
    May 28, 2018
    My purpose is just to eliminate the casual theft of convenience. There are a lot of other trailers in my area - if mine is just slightly more difficult to steal then it's safer.
    xxxapache, soft 17 and Rik Peery like this.
  13. DMichael
    DMichael New Member
    Apr 4, 2017
    It was our trailer that was stolen. We had a lockable pin through the ball mount and someone cut it with a bolt cutter and drove away with it when it was parked in front of our house. Now, we store it at gated secure storage lot with a couple lock that fits up into the ball mount and goes over the top with a hardened steel loop (doesn't appear bolt cutter cuttable, at least not easily.) When we have it at home prepping for a trip, we put it in our driveway, still use the tongue lock, put the car right up next to it, lock one of the safety chains to the car, and put it up on the bal tire leveler. Like people said above, if someone REALLY wants your trailer, they can take it, but we're hoping to at least slow the process down and make it not worth the effort.
  14. nineoaks2004
    6,005
    2,204
    Graceville, Florida
    I use a case hardened long shaft lock, Where I live I am not worried about someone stealing my unit but it is for me when I hook up to it. Pins, nuts and bolts have a way of (not often) working loose and this is for sure not working loose. I had a boat trailer that came off my truck, I was going slow the run away was stopped by the neighbors mail box I re-hooked installed the lock and we went fishing
  15. tfischer
    tfischer Well-Known Member
    3,092
    634
    May 21, 2014
    It's a level of security. If someone wants in your house they will break a window or kick in a door, yet we still have locks.
    terry1419 and Rik Peery like this.
  16. Rik Peery
    398
    236
    Jun 15, 2018
    Virginia
    Sorry to hear, making it hard to take is all one can do for sure; a few years ago, thieves were stealing trailers/grills/etc out of neighborhoods here, many in broad daylight, went on for almost a month, never did catch the culprits I don't think...
  17. e_lizzle
    e_lizzle New Member
    Mar 6, 2018
  18. Rik Peery
    398
    236
    Jun 15, 2018
    Virginia
    Looks like a good one for sure, thanks for the link; have a wheel lock I use & live on a ridge w/ one way up, one way down, nary a prob in 24 yrs, BUT...making a drive away difficult is the goal, & every little bit helps...pal has a little alarm he sets in his kayak when he's away from his truck, has it cabled locked, but somebody set it off in his neighborhood one evening, said it's loud as hay, but a good deterrent...
  19. Fbird
    Fbird Active Member
    262
    112
    Sep 10, 2017
    Ferndale MI
    All the lock is for is to keep a honest man honest and peace of mind. If someone wants it a lock isn't going to stop them.
  20. Toedtoes
    1,010
    623
    May 28, 2018
    I see it as levels of protection:
    No locks and anyone will take it.
    Simple locks and alarms will deter "opportunity" thieves "hey look at that, think the door's unlocked?". (Statistically teens and young adults).
    Beyond that, you are trying to stop professional thieves and/ or subject matter thieves (the ones looking specifically for what you have). These are the folks with tools to do the job and/or who are willing to risk a lot to get what they want.
    How much effort you put in is dependent upon your risk assessment for that level of theft.
    tfischer and Rik Peery like this.
