CPAP First Time Camping
Discussion in 'Camping for the Medically/Physically Challenged' started by BigRedTruck, Jul 9, 2016.
  1. BigRedTruck
    BigRedTruck Member
    428
    Jan 23, 2011
    Thanks for the lessons learned. The bigger inverter would be nice. And I agree, the smokey CPAP sound just fine now!
  2. West Coast Canuck
    1,620
    36
    Mar 3, 2005
    I bought a Group 31 AGM battery (105 amp hour) to power 2 CPAPS without the humidifiers since my wife and I use them. We mostly dry camp and do run it thru an 400 watt inverter. I will be getting the 12 volt cables for the cpaps to run it direct to save the power loss thru the inverter. I also bought the Go Power 120 watt suitcase solar panel to charge the battery and have my Champion 2000 or 3100 watt inverter generators to charge with on cloudy and rainy days. I also have two 6 volt (220 amp hours) Interstate deep cycle batteries
    that I use for our TT.
  3. Camp Addict
    Camp Addict Member
    210
    Apr 15, 2010
    Las Vegas
    BigRedTruck
    Good luck with the VA. I tried and they said NO. They didn't even think about it. In my case anyway. I just cut my cord before the converter and put male terminals on it. I got some 18 gauge lamp cord, put female terminals on one end and a connector from our solar kit like this upload_2017-4-14_14-47-28.png on the other end. I just plug it into where the solar panel plugs in before bed. And of course, no humidifier as it's too much of a power drain.
    BigRedTruck likes this.
  4. BigRedTruck
    BigRedTruck Member
    428
    Jan 23, 2011
    Ok, this is on my bucket list! Thank you for posting!
  5. GrueMaster
    GrueMaster Active Member
    139
    41
    May 22, 2013
    Saint Helens, Oregon
    I have the ResMed as well. Never thought about removing the humidifier, I just usually have it set to 0. I bought the 12v car adapter many years ago, and actually used it once when hammock camping with some friends (I tied one end of the hammock to a tree, the other to my truck bed and had the cpap in the passenger seat - somewhat comical, but it worked). Now, I have added a 3 port accessory block (with separate USB charger port) inline to my trailer, vampiring into the water pump power feed and mounted under the lip of the countertop. I also take my portable jumpstarter as a backup for longer camping trips. We recently camped the entire week before Memorial Day, and the battery held up with both cpap and heater running until ~3am Thursday night (I have a 45W solar array I put on the roof when parked - helps keep the battery charged). After switching to the jumpstarter, I slept through until almost 9am (I'm usually up at first light). My friend had a Honda 2000i, so we ran an extension cord and charged up off that, then were good to go until Sunday pack out time.
  6. bob barnes
    bob barnes Well-Known Member
    1,343
    195
    Mar 26, 2017
    I have been on cpap for years funny I never take mine camping whether here or Europe. I have been gone up to 2 ms without one!
  7. Michaeln
    Michaeln New Member
    Sep 4, 2018
    Avery, California
    Using the CPAP mfg's DC cord is way more efficient than using an inverter with a battery and running the CPAP off of AC (inverter). If you do it that way you have to convert DC (the battery) into AC (the inverter and normal power cord for the CPAP) and then back to DC to actually run the CPAP. There are energy losses at each stage of that process because none of those conversions are anywhere near 100% efficient.
    I have a Resmed Airsense 10 with their 12v to 24v DC adapter cord (the CPAP actually runs on 24v DC even when you plug it into your home 120v AC wall outlet), and I power it off a Renogy 100ah gel cell battery. I can get two nights out of it including using the humidifier and heated hose.
    jnc likes this.
  8. dbhost
    dbhost Active Member
    183
    46
    Sep 19, 2018
    League City, Texas USA.
    Haven't been camping since I went on CPAP. Good to know. I like the campfire smell anyway. Oddly enough it helps me sleep. Probably a bad thing come to think about it...
    FWIW, I have 2 CPAP machines, one failed that insurance replaced early. The failed unit is getting sent out to a repair facility in Houston and for less than the cost of a decent 2K sine wave inverter, I will have a second CPAP working and ready to go. That one will stay stashed in the camper and ready to go. If you have replaced a CPAP and the old one is working, just get a mask / tubing / filters and keep that spare for camping if you don't want to have the smokey smell at home...
