Crank down stabilizers to replace fold down
Discussion in 'Stabilizing Your Camper' started by mjoffive, Mar 10, 2017.
  1. mjoffive
    mjoffive New Member
    Aug 16, 2014
    Hello, friends. I have an opportunity to replace two fold down stabilizer jacks in the back of box with 4 crank down ones. We have an 1998 Jayco 8 foot box and 4 crank down jacks seem like it might be overkill, but we do feel movement with just the two fold down stabilizer jacks in the back.
    Any thoughts? Are they easy to install on the camper frame? Thanks so much. This forum is so very helpful!
    Mary
  2. Snow
    8,157
    126
    Ontaio
    Lots of members here have done the same mod.. The crank downs might need new holes drilled if your going to bolt them on, but almost any welding shop or local welder will be able to weld them in place.. Just remember they are only to stabilize, not to level..
  3. durhamcamper
    durhamcamper Member
    436
    Apr 21, 2010
    Pickering, Ontario
    Our previous pup (a 2001 Dutchmen) had just the fold down stabs when we bought it used but had 4 crank down stabs installed by the dealer we purchased it from. They just used large self tapping metal bolts and we were very happy with the results.
  4. mjoffive
    mjoffive New Member
    Aug 16, 2014
    Thanks all for the info. Now all I have to do is hear back from the guy selling them. I'll let you all know how it goes.
    Mary
  5. friartuck
    friartuck Active Member
    2,617
    Nov 1, 2007
    Perry, MI
    I replaced the drop downs with crank downs on my Yuma, and never looked back. They were easy to install, following the instructions, and made a world of difference in setup time, no more trying to fight the stabs down on an unlevel site! Again, just remember these are for stabilizing, not leveling the camper
  6. mjoffive
    mjoffive New Member
    Aug 16, 2014
    I have read through threads warning of not using stabs for leveling. We level first and stabilize during setup.
    Unfortunately, the party who was to sell them to me ($30 for all four) backed out, so now I'm looking for my next best option. I saw some corner rv stabilizers for sale on ebay, but I'm not sure what those are.
  7. Snow
    8,157
    126
    Ontaio
    Walmart sells stack jacks in a set of 4, you could use one under each corner of the frame to stabilize the pup as well ..
    ST Dog likes this.
  8. Dudman5703
    Dudman5703 Jeep Guy
    186
    21
    Apr 17, 2012
    Grand Rapids, MI
    Oh our new one we got the crank down stabs. I personally would have done this mod on my old one had I known its so convenient compared to my old pull downs in back and Jack stands in front.
  9. XKPin
    XKPin There's no situation so bad it can't be made worse
    197
    25
    Oct 28, 2016
    Gloucester, Virginia
    . . .add a battery powered hand drill and socket and it's a wiz!
  10. 4xMeteor
    4xMeteor Active Member
    548
    27
    Jul 30, 2012
    Georgia
  11. Haybale
    2,224
    65
    Aug 22, 2013
    San Diego via MN
    Head to your local junk hard and buy the scissor jacks.
    That's what I use on the front of my 6ft box pup to add stability (factory fold down stabs in the rear). I use an 18v 1/2in impact (it does not go into hammer mode) and it is very quick. I do use a block of wood between the jack and the frame to keep the metal on metal rubbing noise down.
