Do we need to lube our Slide-Outs?
Discussion in 'Slide-Outs / Bunkends' started by Halford, Dec 17, 2018.
  1. Halford
    Halford Well-Known Member
    3,442
    440
    Sep 28, 2011
    Santa Clarita, California
    That got me wondering when I was camping last weekend: do we need to lube the slide-outs? anyone done it?
  2. Sjm9911
    1,992
    794
    Dont have a slide out, but i think anything that moves needs a little lube now and then. So yes.
    tombiasi likes this.
  3. BillyMc
    BillyMc Active Member
    369
    110
    Mar 25, 2018
    I lubed my bunk slides with spray white lube and they move a lot easier. They looked like they never had any lube at all.
  4. McFlyfi
    McFlyfi Active Member
    261
    85
    Aug 1, 2014
    Thousand Oaks CA
    I do all slides (including the bed slides), lift posts, and pulleys at least twice a year.
  5. xvz12
    xvz12 Well-Known Member
    659
    315
    Apr 6, 2017
    New Plymouth, ID
    When I first bought our pup, it was nearly a two man job to pull/ push the bunkends, a shot of dry silicone spray, & now I can move them one handed.....made a HUGE difference. I spray them at the start of every season now.
  6. jmkay1
    3,723
    804
    Umm never lubed my slide out but really wouldn't be that hard to do since I'm already under there during my winterizing process. Probably would be a good idea to keep everything moving. I've drylubed the bed slides every season sometimes more and cleaned out the rail track once in awhile to prevent it from gumming up. That's actually something i forgot to add to my list, dry lube. Used the last of it up on my last camping trip.
  7. xxxapache
    2,547
    610
    I lubed the pull out beds and lift arms on my Apache with silicone often.
    I keep a can of silicone in my TT. I use it on lock striker plates, dump valve pull rods, garden hose fittings, awning arms, ect.
  8. tzmartin
    tzmartin Active Member
    732
    204
    Sep 9, 2015
    yes about once a year
  9. BikeNFish
    BikeNFish Well-Known Member
    1,780
    1,005
    Apr 24, 2017
    Maplewood, MN
    I lube the bunk slides and lift posts a couple times a year with WD-40 silicone spray. If I had a slide out, I would use it there, too.
  10. Shaman1
    Shaman1 Well-Known Member
    1,339
    165
    May 13, 2011
    Oklahoma City, Oklahoma
    I do it every spring.
  11. William Freeman
    William Freeman Active Member
    145
    55
    May 5, 2018
    Richburg SC
    Something else I need to pack for the trip this weekend - so I can lube it while the dinette is slid out. I sprayed the bunk ends this summer but didn't even think about doing the slide while it was out!
  12. BikeNFish
    1,780
    1,005
    Apr 24, 2017
    Maplewood, MN
    Yeah, sometimes I forget the obvious too. I re-waterproofed the screen side of my bunk end window flap from inside the pup after I scrubbed the bunk ends, then didn't realize until the end of the season that I never got around to re-waterproofed the outside of the bunk ends. When it rained, I couldn't figure out why the water was soaking through the canvas sides. DUH!!
    William Freeman likes this.
