Door frame is jacked up!!!!!!
Discussion in 'Miscellaneous Repairs & Maintenance' started by Leslie Loring, May 12, 2019.
  1. Leslie Loring
    Leslie Loring Member
    36
    Feb 9, 2019
    Little Rock
    I am really getting cranky because I keep running in to the “joys” of owning an older PUP!
    I have a 2001 Starcraft pop up. The door frame at the top interior was welded by someone before I purchased it and one weld broke tonite. There are two welded corners on the top of the inside frame of the door and one welding spot on the bottom of the exterior of the top section of the door.
    I tried to load the pictures I took tonite but get an error message that they are too big. I’ll work on that.
    Please share any ideas or experiences you’ve had in repair the door or frame.
    I have a few ideas but would much rather learn from someone else’s trial and errors.
    I have contacted a few online companies to ask about replacement frames or doors but it’s a Sunday so I don’t expect to receive a response for a day or two.
    Thanks everyone!!
  2. Leslie Loring
    36
    Feb 9, 2019
    Little Rock
    145394A3-F15D-4566-99E9-46A936D09839.jpeg FA66EF38-6A3B-49A2-B54B-680468045ACA.jpeg 606BDD3E-EA18-43E1-BAF9-822711684752.jpeg
  3. Kampus
    Kampus Active Member
    127
    108
    Jun 16, 2017
    Slate Belt, Pa
    If it were me, and you have the meat on the frame, I would sand the broken weld flat and try some L brackets and rivets.
    Sjm9911 and Milemaker13 like this.
  4. bols2Dawall
    bols2Dawall S.W. Ontario
    1,396
    111
    May 19, 2010
    Lasalle Ontario
    or get a pro to re-weld it
    Sjm9911, 1380ken and Milemaker13 like this.
  5. daveo1289
    daveo1289 Active Member
    948
    43
    Apr 24, 2012
    Rochester NY
    It looks as if I welded it!! Aluminum is not easy to weld properly. It takes special equipment to do it right. I'm with bols2Dawall. Get a pro to fix it.
  6. Matt Benoit
    Matt Benoit Active Member
    411
    228
    Jul 30, 2017
    Warren, MI
    The preferred way would be to have it welded by a pro. However the last time I needed something tack welded (let alone something aluminum) I called a dozen places and you would have thought I asked them to bid on a government contract! Unless you know a welder or have a friend that can do it, you might have the same problem I did in my area. If I was in your shoes I'd probably use some angle brackets and rivet them together. Would be plenty strong and not look like an eye soar.
  7. 1380ken
    1380ken Well-Known Member
    1,885
    390
    Nov 7, 2013
    Mass
    I wonder if those corners are designed to flex. A corner bracket may be better than a weld.
