Door leaks
Discussion in 'Miscellaneous Repairs & Maintenance' started by mrjam2jab, May 19, 2017.
  1. mrjam2jab
    mrjam2jab Member
    75
    May 29, 2014
    1985 Coleman Sun Valley
    When it's set up and it rains, rain gets in the door thru the bottom of the slider window. Is this common or a worn out "seal" of some sort?
    The top is the slider
    Water is running down the lower panel, collecting in this track, and also winding up on the floor.
  2. davekkk
    davekkk Member
    315
    Oct 7, 2013
    Never had this problem with ours and we have been in some very heavy rain. I'll inspect next time I have it up, sorry I couldnt be more help.
  3. Make sure that your slider window is in the back track of the door frame. On mine it seems like it will latch closed at times but not be in the deeper track.
    You should be able to remove the slider and check for a gasket (or a slot for one) on it and/or the outside door frame. Mine isn't accessible right now or I'd look at it for you.
  4. BelchFire
    1,208
    30
    Mar 29, 2012
    SE Georgia
    We use our awning. I don't know that our door has ever been wet. A bag awning is a cheap solution if you don't already have one.
  5. davekkk
    davekkk Member
    315
    Oct 7, 2013
    This is a good point, I use our awning all the time too which may be why I have never had this issue.
    Will be curious on what you find out. There is unsealed wood at the bottom of the door plate so you really dont want water coming in and dripping in below there. I thought of taking the plate out and sealing it up with something at some point.
