Dust Cap Won't stay on
Discussion in 'Tires / Brakes / Bearings / Axles' started by afidmt, May 6, 2018.
  1. afidmt
    afidmt New Member
    18
    Jun 3, 2015
    Colorado Springs, CO
    I have a '95 Coleman Montauk - PUP -- when I purchased it (second Hand) I had the bearings repacked - and on the first trip -- The dust cap fell off on the way home - and tire blew -- since then I have tried to replace the cap - and it won't stay on - it seems to fit fairly tightly and seats well (need to use a rubber mallet to seat it ) - but after just 5 miles or so - poof -- off it comes -- I have checked the tire and castle nut and the tire is seated correctly - My question is - should I just give up and replace the HUB or is there anything else to try to keep the cap on ??? If the consensus is to replace -- would any #2500 hub kit work???
  2. xvz12
    xvz12 Well-Known Member
    672
    326
    Apr 6, 2017
    New Plymouth, ID
    Take your old cap to any real auto parts store, they will have, or can order a replacement cap for you It may not be the problem, but it's pennies compared to a new hub. Make sure you take the old one with you so they can measure it.....if they try to measure it with a tape measure, rather than calipers, take it do a different store
    xxxapache and jnc like this.
  3. jnc
    3,896
    1,139
    Oct 1, 2014
    South Central New Hampshire
    If @xvz12 's don't work I would try some gasket sealer. I know it's not pretty but it is cost effective.
  4. joet
    3,725
    567
    Instead of using a gasket sealer. I would use Loctite.. no mess
  5. WrkrBee
    WrkrBee Well-Known Member
    1,170
    412
    Get the right part. You want to take a chance of pushing gasket sealer or Loctite into your grease? If you ran any distance with the dust cap off, you probably picked up sand in the grease and need to replace the grease. Grease + grit = lapping compound.
    xxxapache likes this.
  6. nineoaks2004
    6,005
    2,205
    Graceville, Florida
    try a new cap, if it will not stay on the lip on the hub could be worn, On my 16' utility trailer I used a couple of layers of duct tape and that is tight enough to hold it on. X2 on pull the wheel bearings out and re-pack
  7. WrkrBee
    1,170
    412
    You may be able to take the old dust cap and enlarge the hub seat with a ball peen hammer and vise. It make take a little experimenting on where on the vise to hold the cap to maintain the right curve. Keep playing with it until the fit is correct.
