Found two leaks in the plumbing system
Discussion in 'Plumbing Systems (The Fresh, The Blue, The Grey, &' started by theseus, Jul 12, 2017.
  1. theseus
    theseus Centerville, OH
    2,274
    150
    Feb 6, 2007
    Centerville, OH
    I was sanitizing the tank today preparing for my trip to the Tetons and noticed water dripping from two points on the plumbing.
    The first was at the pump, I discovered there was no washer on the tank side of the pump. So I replaced the line with a new line that had the right washer and installed a new style debris filter while I was working with it.
    The second was the cold water line to the outside shower. Fleetwood just drilled a hole and passed the line up through the floor. Time and I guess movement wore a hole in the water line where the floor and line touched. Easy fix but something I would have never thought would happen.
    So now you all have something else to look for chasing leaks...;)
  2. mstrbill
    mstrbill Active Member
    417
    72
    Mar 17, 2013
    Austin , Texas
    If you have a external shower in the dinette slide, it's quite common for the cold/hot lines to break at some point. IIRC you can just use off the shelf hoses to replace.
