Frame up resto of front cargo box on 97 Coleman Key West
Discussion in 'Miscellaneous Repairs & Maintenance' started by Dsled, Jul 11, 2019.
  1. Dsled
    Dsled New Member
    25
    May 21, 2019
    Mountlake terrace washington
    Hey there , I posted a couple of threads about my repair of the front cargo box, so I want to post pic's of each phase. So i'm going to do it in a few posts.
    I started by stripping it all off down to the frame. Then I treated all the rust with stabilizer , then painted it with rust inhibiting paint. 3 pic's
    The next thing I did was tapes off the hole around the frame and blocked off each end. Then I filled the bottom of the front panel with spay foam to make it more ridged just up to floor level. Then I went over all the edges of the corners with foil tape to give it a little more structure. 3 pic's
    Next come the wood. I started with 3/4 plywood for the floor and added more cartridge bolts to hole it down better. Insted of put 2 small pieces on the front support brackets I use 1 piece of 1/2 treated plywood 40" long to tie them together. the site won't let me upload any more pic's to this tread so I have to start another one , sorry what a pain
      File size:
      143.3 KB
      File size:
      188.4 KB
      File size:
      181.7 KB
      File size:
      182.9 KB
      File size:
      84.9 KB
      File size:
      116.2 KB
      File size:
      148.8 KB
      File size:
      127.5 KB
  2. WrkrBee
    WrkrBee Well-Known Member
    1,935
    725
    You can do it on one post by using the "Edit" button (bottom left). That keeps all the info in one place, for people looking for this same issue, in the future.
  3. Dsled
    Dsled New Member
    25
    May 21, 2019
    thank's for the info I'm new and don't really know how it all work's . Any idea why it posted 3 set of pic's? did it normal like , and can you delete or change a pic once it been posted?
  4. Sjm9911
    3,660
    1,799
    The bunk wall wasn't effected? Man you lucked out!
  5. Dsled
    Dsled New Member
    25
    May 21, 2019
    Only a little bit at the bottom corner by the outside wall and the corner of the pass though , but structurally yes it's in good shape. Just saved it...
  6. WrkrBee
    1,935
    725
    Try the "Edit" and see if it will let you remove some pics. I've had double post when the site was running weird.
  7. Dsled
    Dsled New Member
    25
    May 21, 2019
    Tried that delete all pic's then reload , you can see what I ended up with
  8. WrkrBee
    1,935
    725
    PopUpSteve may be able to undo the pic mess and tell us how to avoid it.
