Going Solar, Renogy 100-watt Folding Suitcase Panel Kit
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by Firehawk068, May 23, 2016.
  1. sailorguy1
    sailorguy1 New Member
    Mar 27, 2015
    Best connectors around are by Powerwerx with 10 gauge wire
    folding panel with mppt controller works great and moves to the sunlight a fixxed panel adds to the power when not in the shade
    mount a 100 watts on the roof with Solar Panel Universal 4-corner Drill-free Glue Mounting Brackets for Rv amazon or hose clamps to the roof rack
    CT-75 PP75/SB50 Powerpole Crimping Tool for 75 & 50 amp
    Boot-SB50 Corrosion Proof Safety Boot for SB50 Amp Housings
    DUST-SB50 Dust Cover for SB50 Amp Housings
    5952 PP75/SB50 Loose Piece Contact (Gauge: 8)
    5900 PP75/SB50 Loose Piece Contact (Gauge: 6) used to marry to 10 gauge wires together
    5913 Reducing Bushings for Powerpoles (Series: PP75/SB50, Use with Contact (Gauge): 5900 (6), Reduces to Wire Gauge: 14 or 16)
    Wire-RB-10-50 Red/Black Zip Cord (Gauge: 10, Length: 50 ft.)
    SB50-10-BLK SB50 SB Series 50 Amp Anderson Powerpole Kit (Color: Black, Gauge: 10)
    This set up give plenty of power for Cpap and most anything you wish to run
  2. michaeltdyer
    michaeltdyer Member
    118
    Nov 26, 2012
    Denver Colorado
    Silly question, but is there any reason you could not put some plastic over the controller to make it waterproof? Maybe even put the controller in a plastic box and bring the wires out of a grommet?
