Gray water collection w/ outdoor shower
Discussion in 'Port-A-Potties / Cassette Toilets / Bath Houses' started by Steve in Denver, Jan 21, 2019.
  1. Steve in Denver
    Steve in Denver Member
    62
    Sep 1, 2018
    Title pretty much says it all. I have an external shower and a pop-up tent for an enclosure...and a gray water tank for storing the water...the part that is missing is a way to catch the gray water. I was thinking about a plastic tub to stand in while showering, then dump that into the tank...so far I haven’t found a suitable tub...the mortar mixing tubs that Lowe’s/HD sell are close, but the dimensions aren’t ideal.
    What is everyone else doing?
  2. Blackripley
    Blackripley Member
    99
    63
    Jul 21, 2018
    Goleta Ca
  3. sleach
    672
    139
    May 17, 2014
    Boulder, Colorado
    We catch the bathing water in a mid-size plastic tub. The tub doubles as container for trailer set up supplies like chocks, leveling boards, stabilizer crank, doormat, etc. and travels in the back of the pick 'em up.
    Showers emphasize minimum water use. Wet down, shut off, lightly soap, rinse. We have no built in gray water storage, so bath water goes in the six gallon jug. A really big mouthed funnel catches what we pour from a corner of the tub.
  4. PopUpSteve
    PopUpSteve Administrator
    18,563
    1,410
    Dec 22, 2002
    Malvern, PA
  5. jmkay1
    4,439
    1,382
    Like blackripley I considered the same item. I haven't had need to use my outside shower yet so not sure how well it will work . I just really like it can fold up.
  6. GreyFox
    GreyFox Well-Known Member
    980
    442
    Oct 10, 2018
    S Ontario
    Back 100 yrs ago when we camped in a Fleetwood Santa Fe we also owned a Paha TeePee shower tent so we could use the camper's outside shower faucet as a source of warm water.
    https://photos.google.com/share/AF1...?key=Y0tiYWFzQl8xdGRCRmwwOV90TXBtYlpOZHdRc3VB
    The TP had a fabric floor insert so on top of that I'd drop an old towel to catch any over spray and we'd simply stand in a small Rubbermaid tub that would catch most of the water and we could air dry later. Worked just fine - K.I.S.S. - no need for anything more complicated than this. We found that having our own shower facilities really handy so later on I added my own DIY inside shower and eventually didn't bother with the outside version.
  7. Steve in Denver
    62
    Sep 1, 2018
    Lots of good replies - thanks.
    [QUOTE K.I.S.S. - no need for anything more complicated than this. [/QUOTE]
    Yeah, sometimes I need a reminder.
    I bought one of these...I will give it a try this spring:
    https://www.homedepot.com/p/Medium-Mixing-Tub-26100/301943161
    It's 28x20, so it should be able to catch most of the water
    Thanks again
    -Steve
  8. Jenkamus
    Jenkamus Active Member
    216
    51
    Oct 17, 2015
    Surprise, AZ
  9. dbhost
    dbhost Active Member
    528
    199
    Sep 19, 2018
    League City, Texas USA.
    Wonder how you get that thing to stay open. I think when set up the water in it is what's supposed to hold it open.
    After digging into the images, it looks like it is self opening, and does not need water inside to hold it open. This just got put on my wishlist...
  10. Dan Wilson
    Dan Wilson Member
    78
    43
    Jan 30, 2019
    Appleton, WI
    I use an oil collection container I bought at Home Depot. It looks like a five gallon container but lays on its side with a small port and collects the water. It holds four gallons. My shower takes about one and a half gallons. I then close the port and carry the container by its handle to the nearest bathroom and dump. It cost $11.
  11. inthedirt
    inthedirt Active Member
    870
    86
    Aug 28, 2012
    SW Montana
    I use biodegradable soap and like to think I'm "watering" the local vegetation. Of course, I boondock 99% of time and don't have CG rules to follow. Just one of the perks of living in God's country where cattle outnumber people 10:1
    HappyTraveler and Overland like this.
  12. roybraddy
    roybraddy Well-Known Member
    2,065
    702
    Mar 23, 2016
    King George, Virginia
    If you just want to catch the water and run off under a close by tree etc this might work. This is a Hot Water heater pan for the house. Can be picked up at any hardware store like ACE hardware etc...
    This comes with a standard hose connection...
    Google image
    Roy Ken
  13. dbhost
    528
    199
    Sep 19, 2018
    I wonder how much water + feet that thing will hold... Of course if you are in a hilly spot, and can run the hose downhill, connection to a gray water container would be a snap.
  14. Dan Wilson
    Dan Wilson Member
    78
    43
    Jan 30, 2019
    Appleton, WI
    Here is a photo of the oil collection container I use for grey water under the shower. It holds four gallons. IMG_1279.JPG
  15. Chloe
    Chloe Active Member
    161
    65
    Jun 16, 2017
    Massachusetts
    Some great suggestions here!
    We have the PahaQue TePee tent, like one of the previous commenters, and then we got the Drain Capture Floor to go with it: https://www.amazon.com/dp/B000EWE91A/
    I think both of these items have been discontinued. We haven't even been able to test ours out yet but I'm determined to bring it with us on our next trip after suffering a cold shower one evening at the last campground. Assuming my DH can get the hot water working in our Aliner, lol.
  16. Sjm9911
    3,660
    1,799
    If i had to build one, and i dont. I would look into a pan or catch system that would rest on like 2 milk crates, then a drain to gray water tank. Milk crates can hold food, supplies, for travel then do double duty as a makeshift stand for the basin. Good luck to all your builds.
  17. dbhost
    528
    199
    Sep 19, 2018
    Okay I have been doing the thunking here as it were on this...
    I can only use my example as I don't have your setup exactly so bear with my stupidity here...
    Using this above linked doggie pool, it collapses and stows when not in use. Has a usable waterbed type drain you can use to pour into a gray tank, and...
    Given the 32" small size model, if you hvae one of the large privy tents, the port o potty can get moved out of the way into the corner, this can be set up, and away you bathe without having to remove the toilet. Given those items of note, I am going to order up the small size for our privy.
    While I have never known of any gray water collection rules for shower tents at the state parks, it appears they do have them, and you folks have made me paranoid.
  18. Blackripley
    Blackripley Member
    99
    63
    Jul 21, 2018
    Goleta Ca
    Do you stand on it?
  19. dbhost
    528
    199
    Sep 19, 2018
    How does that work? Even someone skinny couldn't safely stand on it without buckling it, or slipping off...
  20. Orchid
    Orchid Sharp Shootin' Grandma
    5,154
    1,819
    May 8, 2011
    Florida by way of WV and MD
    My first thought was that he puts it under the shower drain coming from his camper.
