Heater rattle
Discussion in 'Heating / Cooling Systems' started by Snowman, Aug 16, 2017.
  1. Snowman
    Snowman Member
    71
    Jul 12, 2017
    Boulder, CO
    Hey folks,
    The heater is my '98 Santa Fe makes a sort of whirring/rattling sound when it's running. If the thermostat comes on at night, it's loud enough to wake up my wife (and sometimes me). Any idea what might be causing it?
    Thanks!
  2. xvz12
    xvz12 Active Member
    412
    157
    Apr 6, 2017
    New Plymouth, ID
    Sounds to me like either you have a bearing going out in the fan motor, or something loose rattling around inside the squirrel cage. Either way, I imagine you're going to have to pull it out to fix it, we'll hope for the 'something loose'...that's the cheaper fix, good luck
  3. McFlyfi
    McFlyfi Active Member
    118
    26
    Aug 1, 2014
    Try this first- when it comes on, check the vent grate covering. Ours vibrated pretty badly, but a little weatherstripping between the grate and the wall fixed that rattle.
  4. Snowman
    Snowman Member
    71
    Jul 12, 2017
    Boulder, CO
    OK, so I may have mis-stated the issue. Upon listening to it again, it's more of a squeal/squeak while running. Does anything need to be lubricated on this heater?
  5. ~erik~
    ~erik~ Active Member
    286
    41
    Jan 19, 2015
    North Georgia
