Help with tires
Discussion in 'First Time & New Camper Owners' started by chadster, Apr 16, 2018 at 7:54 AM.
  1. chadster
    chadster New Member
    Mar 12, 2018
    Utah
    Hello all. Once again I am asking a question hoping for guidance. I have been doing a lot of reading here on tires and a little over a month ago I got a great deal on a Coleman Sedona 2002. We are trying to get everything camping ready so we can go out for a weekend in May. One thing I discovered is the tires on the trailer are from the 51st week in 2001. Wow the previous owner who was the first owner was right... He didnt use it much. I don't feel comfortable towing it and my family with those old of tires. So replacing it is. I've noticed a lot of places sell tires on rims I think I'll go that route and just have a nice cleaner look. Anyways here's the info I have on the tires
    Can you guys help me with recommendations? I do live in Utah and we have interstates with speed limits at 80mph that's another discussion but I think it's way too fast even if not towing. I would like a tire where I can cruise nicely at 65, with the occasional 70 if I need to pass a semi etc.
    I'm leaning towards radials if possible but open to suggestions.
    Thanks in advance everyone.
  2. JPBar
    JPBar Well-Known Member
    1,509
    342
    Sep 22, 2016
    Texas
  3. xxxapache
    2,145
    368
    Carlisle Radial Trail HD in that size are rated to 81 mph.
    Fbird likes this.
  4. giadiep
    giadiep Active Member
    280
    91
    Sep 5, 2015
    Syracuse, NY
    I have these on my dual axle HTT. They have been trouble free. The extra margin is nice to have. I typically tow at around 70-75 mph.
  5. MNTCamper
    MNTCamper Active Member
    545
    46
    Jun 14, 2014
    It is a common trailer tire size ST173/80D13. Given the GVWR of the trailer, you would be fine with a load range C tire, but you can also get those in a load range D tire which would give you more margin for loading. In any case, as noted above, there are ST tires out there speed rated for >75 mph so that you can tow at faster speeds if you want. You can get tires on rims or just get new tires and have them put on by your favorite tire place.
  6. markzrt1
    markzrt1 New Member
    21
    Oct 15, 2010
    I will be ordering tires on rims from etrailer soon.
  7. tenttrailer
    2,606
    93
    Jul 18, 2013
    Thornville, OH
    I would get away from the bias ply tire ST173/80D13 and go to a radial tire ST173/80R13 they run much cooler. Heat decrees tire life. I like the goodyears ST tires.
  8. xxxapache
    2,145
    368
    I also would probably go radial. The good thing about bias ply is they don't do near the damage a radial does if you have a blow out.
  9. popupmtber
    popupmtber Member
    30
    Apr 4, 2018
    I always thought bias ply was better on trailers that don't get used very often (like my pop up), but if you're using it all the time then go with a radial. Is that not the case?
  10. giadiep
    280
    91
    Sep 5, 2015
    Syracuse, NY
    Bias tires are technically more resistant to "flat spotting" based on their construction. However, tire technology has improved so much that "flat spotting" isn't that big of an issue on radial tires anymore. Just about every car on the road today uses radial tires. They sit on radial tires while on a cargo ship or truck or rail for weeks at a time. Plus, after a couple of miles on the road, the "flat spotting" deformity works itself out anyways.
  11. chadster
    chadster New Member
    Mar 12, 2018
    Utah
    Well great I had no idea what "flat spotting" even was. I just barely ordered and got radials from etrailer. Should I call and switch to bias?
  12. xxxapache
    2,145
    368
    Radials will be fine.
  13. giadiep
    280
    91
    Sep 5, 2015
    Syracuse, NY
    No. Radials are fine. Actually I prefer Radials and have them on my HTT. I think most people here prefer Radials, but I won't speak for them.
