How to wire standard receptacle..wires are compressed into back? Pic attached
Discussion in 'Wiring' started by Donald Zahner, Dec 2, 2018.
  1. Pozi
    Pozi Member
    76
    21
    Feb 17, 2016
    When I rebuilt my Palomino the only receptacle I found with the "speed box" type was at the refrigerator. All the others were regular house type with screw terminals. I simply replaced the crappy one with a new. Was able to gain enough slack since I had all the wires out anyway.
  2. Matt Benoit
    Matt Benoit Active Member
    296
    159
    Jul 30, 2017
    Warren, MI
    I too replaced all of my outlets with standard household type with screws..it was maybe $5 in all (old work boxes, outlets and faceplates). Luckily my rockwood had enough slack in the wires.
  3. roybraddy
    roybraddy Well-Known Member
    1,733
    470
    Mar 23, 2016
    King George, Virginia
    Another Problem I have run into trying to reuse those type connections being that the original pinch creases the wiring and you may find like me just a little pulling on the wires cause them to break off at the crease. Then you have to install a pvc junction box and rewire to get some more length. I replace those with the standard screw type receptacles where I can...
    Roy Ken
  4. tenttrailer
    2,859
    183
    Jul 18, 2013
    Thornville, OH
    +2 these outlets are fine. Just don't play with them. Plus, I believe if you take the wires off you should not reuse the outlet. You should install a new one. Something to do with the tension on a reused clip is not the same as a new one.
  5. WrkrBee
    WrkrBee Well-Known Member
    830
    299
    I've reused them, but make sure to move the wire connection at least 1/8" to make a new cut through the insulation and wire. Trying to use the old notch makes a weak connection that can develop into resistance, voltage drop, and a hot spot.
  6. emoney
    emoney Well-Known Member
    866
    426
    Jul 7, 2018
    Not truly relevant to the conversation at hand, but the original topic, I was taught eons ago...(I think it was on
    a slate w/chalk?) that the easiest way to remember how to wire a rec. was "Black Gold". After 30 years, any time
    I need to change out a plug, I say to myself 'black gold' in order to get the wires on the correct side of the box.
    Of course in my particular case, I can't help to add "texas tea" in deference to The Beverly Hillbillies.
    Spridle likes this.
  7. Spridle
    Spridle Member
    713
    Jun 6, 2011
    I had no idea those were a real thing, first I ever saw one like that. I do remember from my code classes that there was strict limits as to how much insulation was allowed inside the box, the fact that these basically have all the insulation intact was the main thing that caught my eye, with the crappy connection itself being secondary. If they are that widely used then they must have proven themselves to be safe, even if they give me uncomfortable feelings. Carry on.
  8. joet
    3,487
    491
    I won't reuse these devices. If I have to replace a recept, I replace the box. Even though they meet code, I never liked them. I replace them with a steel city old work box with wings
